Old 02-01-2019, 02:37 AM
ozzlvlosis ozzlvlosis is offline
Default Upgraded to RME Fireface/No MIDI
I'm using Pro Tools 11. RME Fireface (just upgraded from Babyface) with a Yamaha Motif.
Before I upgraded I was able to get MIDI into Pro tools and use Virtual Instruments like Xpand.
Since upgrading, all I'm getting is audio. From the Motif I have the L/R audio cables going to the fireface and MIDI IN/OUT from the motif to the fireface.
I'm not sure what changed and I'm hoping someone could shed some light on this problem
Old 02-01-2019, 05:50 AM
Default Re: Upgraded to RME Fireface/No MIDI
I'dget the free MIDI-OX utility and run it to see if your Motif is still sending MIDI to the computer. You did install the drivers for the interface right?
Jack
QAPLA!
Old 02-01-2019, 06:15 AM
Sardi Sardi is offline
Make sure it’s all configured properly in Audio MIDI setup. It would have changed as you changed audio interfaces, which is also acting as your MIDI interface.
Old 02-01-2019, 01:13 PM
I will try MIDI-OX.
I did install the drivers and everything looks correct in the settings for Midi I have it in fireface midi port 1
Old 02-01-2019, 02:03 PM
Southsidemusic's Avatar
Originally Posted by ozzlvlosis View Post
I will try MIDI-OX.
Just to make sure //
Midi out from Motif to Midi in and vice versa ?? We have done that mistake of putting midi in to midi in and out to out a few times when stressed hehe
Also check midi thru in PT and that you have the rec button enabled on the Virtual Instrument track. When you wanna use the Motif you need to use a Midi track and an Audio track rec enabled and when using a softwynth you only need a Virtual Instrument track, no midi or audio track.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-01-2019, 02:14 PM
Yes but it's not even working on a VST track. It's as if pro tools can only hear audio and I cant control anything
Old 02-01-2019, 02:47 PM
Control is different from recording MIDI and audio. Motif control of a daw can be strange at times. If you are trying to use controls on the Motif to control things in PT I think you need to use the USB port for MIDI.
Jack
QAPLA!
Old 02-01-2019, 06:19 PM
Maybe control was a poor choice of words. I've just always used midi cables and never had an issue whether it was my mbox2 or my babyface. Now with the fireface uc I'm only getting audio
Old 02-02-2019, 04:30 AM
Have you tried MIDI-OX and if so what did you find? I often find when there's issues with MIDI coming from outside the box it's helpful to look at the incoming MIDI stream even though things may have worked correctly before.
Jack
QAPLA!
Old 02-03-2019, 02:49 PM
I tried MIDI OX. Nothing is showing. I'm starting to think it's a problem with the midi cables or ports on my motif. I tried all the motif settings. I'm gonna try a firewire connection as well
upgraded to 12.8.2, now no midi tracks will play mfaith2 Pro Tools 12 1 08-31-2018 06:51 PM
Upgraded and Lost MIDI centuryson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2010 08:55 PM
Upgraded to PT8 and now can't send MIDI to external synth Odms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2010 02:06 AM
Upgraded Pro Tools - MIDI tracks gone.? tommydigiowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-06-2008 11:22 AM
Finally upgraded to 5.1.1, but now MIDI's gone wacko! Dean Bohana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-05-2002 06:41 PM
