Old 03-12-2014, 06:11 AM
StuR StuR is offline
Default Control 24 - How do you Reattach the PSU
I have recently acquired a Digidesign Control 24 desk, and have had to install a new power unit. As Digi don't release schematics, and I have zero to no experience with opening digital desks, I thought I might ask opinions on if I've reconnected it right.
I have attached pictures to the post, and it is my belief that the circled cables and attachments are all power supplies, and it doesn't matter which order they are attached. Am I right?
Thanks
Old 03-12-2014, 07:40 AM
andrum andrum is offline
Default Re: Control 24 - How do you Reattach the PSU
I used this document:
https://dl.dropboxusercontent.com/u/...nt%20_PCB_.pdf
Pro Tools HDX 2018.12 / MacPro 5,1 2x3.46GHz 64Gb ram / Pro Tools HDX / HD I/O 8x8x8 / Omni I/O
Old 03-12-2014, 03:37 PM
al-andrew's Avatar
al-andrew al-andrew is offline
hi there !
Congrats on your new control surface.
You might want to check this out too
check this link out..... probably worth it :)
Old 03-12-2014, 03:59 PM
crizdee's Avatar
crizdee crizdee is offline
Thanks
Those 3 rows of identical connectors are all the same so it doesn't really matter.
Its the other odd connections and the very small one for the phantom power you need to check are all connected, but they are all different sizes so you can't go wrong
Chris
Producer, Engineer,
www.ukmastering.com
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
