Old 03-12-2019, 02:01 AM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default AAE -9129 - Cpu conflict error crashing Ultimate
Hi all
Old 2010 Mac Pro 12 core - specs in signature
New HDX card and Ultimate
Getting this error - see image
CPU conflict error
I'm running 2 x SSD's - System and Audio
Fresh install of High Sierra
Latest Ultimate - 2018.12
Any help to fix this appreciated.
File Type: png Screen Shot 2019-03-09 at 6.45.59 pm.png (44.2 KB, 0 views)
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
Pro Tools Ultimate 2023.12
HDX card
AVID TB3 1 slot PCie Chassis
Old 03-17-2019, 11:26 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: AAE -9129 - Cpu conflict error crashing Ultimate
I have the same mac pro. And hdx. It's most likely a graphics card issue. If it's the stock card it most definitely is. Get a new radeon 580 pulse 8g card. The pulse fits. The non pulse 580 is too wide.
Sent from my SM-G975U using Tapatalk
Old 03-18-2019, 12:51 PM
the.engineer the.engineer is offline
Could be a graphics issue. I had to change from my 27” Apple LED Cinema Display to a 1080p screen even after I’d upgraded graphics card.
I was told by avid that pro tools 2018 is not optimised for resolutions higher than 1080p.
What screen(s) are you currently running?
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 03-18-2019, 01:40 PM
I’ve ordered a new video card.
Gigabyte RX580 8gb
My 2 main screens are really old
3rd new screen is 1080 I believe.
Thanks for your replies
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 03-20-2019, 08:28 AM
Gigabyte RX580 8gb
RX480 works fine driving a 27" Cinema Display (non-retina) and a HD (1080) monitor. But, driving a Retina display kills Pro Tools CPU usage. Also on HDX.
https://lukehoward.com/
Old 03-20-2019, 11:36 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Sapphire mac edition
4k display at 1440 rez
Plus 2-1080 displays
OS 10.14.3
Was on quadro p4000 in OS 10.13 but web drivers are dropped for mojave.
Old 03-20-2019, 12:54 PM
arche3's Avatar
Gigabyte RX580 8gb
Check on install the 580 is not too wide. Some of them are like a tiny bit too wide so anything next to it bumps into the fans. Its technically 2 pcie slot card. But in reality some of the 580s are wider.
Old 03-20-2019, 01:15 PM
Thanks for the help and info guys
Much appreciated
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 03-20-2019, 07:48 PM
What is your playback buffer set to? Most HDX users I know are pushing that to 512 or 1024 as the solution
Old 03-20-2019, 09:05 PM
Always on the highest setting.
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
PT Ultimate crashing because authorization issues garnoil Pro Tools 2018 7 02-12-2019 04:49 PM
2018.7 Ultimate, Sierra, S3, PT| Control/Dock Crashing bleachbro Pro Tools 2018 2 09-25-2018 04:55 PM
Solution for conflict error on pt [email protected] Pro Tools 10 0 01-17-2014 02:31 PM
TONS of errors: crashing when saving 9092, 9094, 9129 - critically low on memory, etc lemieux Pro Tools HDX & HD Native Systems (Mac) 18 10-18-2012 01:02 AM
USB Conflict? ("lock-up" error) djarcanum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-24-2008 08:20 PM
