#21
Re: Incoming Network Bug - AVID Please Fix!
i just thought it´s good to know for everyone with this issue (including myself) that Avid is aware of it. Some do not read the ReadMe file.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
#22
had this issue, too
I´ve turned off system-firewall and installed this little tool called "Little Snitch" Now I have much more control over network activities and no more such annoying messages
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
#23
Another intermittent one, that is... happens to some but not others.
protools.ideascale.com/a/dtd/Fix-PT11-Firewall-Exception/111660-3779 Reviewing the bug report I see that some had better success manually adding Pro Tools to the Firewall Exceptions List instead of clicking Allow when launching PT. See http://support.apple.com/kb/PH11309 for instructions. Please let me know if this makes any difference for you. Thank you!
• linkedin •
#24
Hello, unfortunately for me none of the suggestions from Apple make any difference. I don't understand why 10 is ok and 11 is not? ;(
#25
Does not work for me too!
#26
#27
My system firewall asks me too if I want to allow PT11 to have network access.
I have some experience with the OS X application firewall so I believe I know what is causing this behaviour. It's basically a security function that notifies the user that the code or a resource of the app has been changed. Apps on OS 10 are basically folders which contain code, other stuff and a secure description of the intended content of the app-container. The system checks on every app-launch if something differs to the secure app-description and if so then the system comes up with this firewall question. So the user gets actually informed that an app was maybe hacked and therefore it is not safe to use it until it is clear why the app isn't exactly as the developer described it with the codesign mechanism. Everybody can verify apps with the system codesign app in Terminal.app or by using the third-party application CodeSignChecker. I did the codesign validation for the PT app file in the installation disk image and there everything was ok (no changes since Avid has coded the app). Then I checked the copy of the app on my system (after installation and after first launch). This is the information I got from the codesign validation about PT11: Code:
a sealed resource is missing or invalid In architecture: x86_64 resource added: /Applications/Pro Tools.app/Contents/Resources/DigiReg.file So what happened? I'm sure that Pro Tools isn't been hacked but there seems to be a routine in the PT code that gets active after the first time the application was launched and then modifies a resource of the Pro Tools application. I don't know why it doesn't happen to all PT11 users. Maybe the routine that causes the change of the app (in my chase a change of the DigiReg.file) only happens in some software / hardware configurations but don't on others. If Avids developers read this: Please check your launch routines inside of Pro Tools. One of them changes the app bundle content and this causes this security issue. btw: several developers have struggled with Apples codesign security mechanism and the result was always that the users are constantly getting this firewall-question. Even Apple had problems with this on some iTunes releases in the past!!! The problem is not that this happens. It's for security! But the problem is that Apple never provided easy to understand explanations in that firewall-question. |
#28
I don't see this at all in PT 11.0.2 on the system in my sig file. What I did have happen was PT 11.0.2 crashed (actually 'program not responding' when right clicking on the icon in the Dock) when I disconnected my Ethernet cable. I didn't need the connection anymore (I had it for syncing my iLok) so I just pulled the connection and then PT stopped working.
On subsequent restarts of 11.0.2 with the Ethernet cable disconnected there were no problems. I never use the Apple OSX firewall. PT 10.3.7 has never shown this problem. |
#29
Hi, yes I actually explained all of what you mentioned recently to Avid technical support.
I too read up on various forums for validating apps etc etc and came up with the same results. Avid dudes...stick a fix in the NEXT UPDATE! Plz. Cheers |
Internet connection dialogue w/ every start resolved | Franco1967 | Pro Tools 11 | 0 | 09-14-2013 10:53 AM |
Icon Locks up on Network connection | roberts | ICON & C|24 | 0 | 04-25-2012 10:52 PM |
Slave Pro Tools to incoming MMC - through what connector? | Mutley Eugenius | Tips & Tricks | 2 | 01-29-2012 06:33 PM |
Fodder For The Nerves | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2008 07:52 AM |
So this is Pro-tools? *shakes head* | CHORDZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 37 | 10-25-2005 12:12 PM |
