Old 07-09-2007, 09:43 AM
LE692 LE692 is offline
Default Using other hardware w/PTLE - it can be done!
Using Jack OSX, VST wrapper, and an MOTU 828mkII, I was able to record 14 inputs DIRECTLY into PTLE v6.9.2 w/MBox. Just thought I'd share this with all who ever wondered if it could be done. The only problems are: 1)latency (easy to overcome with some measurement and file sliding) and 2)I had to use 14 aux tracks to host the JackOSX vst plugs. This was all done on a modest G4 mac mini.
Old 07-09-2007, 11:35 AM
Slim Shady Slim Shady is offline
Default Re: Using other hardware w/PTLE - it can be done!
Yeah, but you still had to have the Mbox attached didn't you?
Old 07-09-2007, 07:36 PM
Of course! It won't run without the mbox. But this way, you can actually record a drum kit or live record an entire band.
Old 07-09-2007, 07:42 PM
OK, you brought the signal in on plugins on 14 AUX tracks - but how did you get it to record those signals to disk?
Quad 2.5 G5, 4.5G RAM
Old 07-09-2007, 08:55 PM
Craig F Craig F is offline
aux track out t via a bus > bus into the track (old trick)
Thank you,
Craig
Old 07-09-2007, 09:05 PM
Asign the output of each aux track to a consecutive mono bus. Then, assign all inputs on the audio tracks to those busses. Record arm them and hit record.
If enough people are interested, I'll make a video of how to do it.
Here' a screenshot:
Screenshot
Old 10-27-2007, 04:23 AM
Ru_C Ru_C is offline
..mm, interetsing...i'm trying to get audio to stream out of another app (Cubase SX) into Protools LE actually....i've got the vst-rtas adapter, & jack OSX, but have got pretty stuck after that...do you have any step-by-step guides to getting this to kind of thing to work with protools? (I'll buy you several beers if you're ever in London !
x
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 10-27-2007, 06:09 AM
Phil Ogden Phil Ogden is offline
x
Why would you want to do this? Would it not be easier to import the full track length audio/midi files into PT and avoid the interfacing/sync issues?
Old 10-27-2007, 06:53 AM
x
..oh completely ! lol....i'm just being geeky......i do however, want to see if Jack OSX is a solution to playing iTunes etc through Digi Hardware, *whilst* protools is up & running....I want to have an Aux track, with Jack on it, & have itunes, quicktime etc 'stream' through it.......problem solved then..
x
Old 10-27-2007, 07:06 AM
Could you take an out from the mac and patch it into a spare input on the D8b?
Strangely, CAD with an mbox2 under OSX 4.10 seems to allow multi client access. I can playback iTunes, QT, Safari etc whilst PT is open and running. Food for thought.
Hardware specs for ptle 8.0.5 dclift 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-03-2013 07:42 PM
PTLE on HD Hardware KingFish Pro Tools TDM Systems (Mac) 5 03-11-2009 01:00 AM
Can u use PTLE w/o a hardware device? DeNiro Tips & Tricks 5 04-19-2007 01:22 PM
using ptle with no hardware? Tony Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-19-2005 09:23 AM
PTLE WITHOUT THE HARDWARE stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-20-2002 08:32 PM
