Old 07-08-2014, 08:20 PM
jspellos jspellos is offline
Default Help (Frustrated) Play button works intermittently
Hi...
Having an issue that occurs periodically (more frequently than not). The play button when pressed sometimes just blinks and doesn't play at all. In addition, I get a "Not Responding" message frequently, either when trying to save a file (on those occassions that I can get PT to work), or sometimes just when selecting a menu item, such as I/O.
I am a newbie here, but I've troubleshooted for the past week, figuring that something is probably conflicting with PT. I had other issues following my installation, but I think I've gotten all of them handled. I'm using ProTools 11.1.3, with an Mbox3. I have a dedicated hard drive for the audio files. I read in a forum that you wanted full system specs, which I have included below. Please let me know what I need to look at to get this working consistently.
Thanks.
Jim
SiSoftware Sandra
ID
Host Name : jspellos-MU2013
Workgroup : WORKGROUP
Computer
Model : HP EliteBook 8570p 103C_5336AN G=N L=BUS B=HP S=ELI
Serial Number : 5CB24*****
Chassis : HP Notebook
Mainboard : HP 17A7
Serial Number : PCSUDB6*******
BIOS : HP 68ICF Ver. F.31 09/24/2012
TPM - Trusted Platform Module : 1.02, IFX
Intel vPro : 8.01.00.1265
Total Memory : 8GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz (2C 4T 3.59GHz, 3.6GHz IMC, 2x 256kB L2, 4MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : HP Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit
Memory Module(s)
Memory Module : Samsung M471B5273DH0-CK0 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Samsung Generic PnP Monitor (1600x1200, 15.3")
Video Adapter : AMD Radeon HD 7570M (6CU 480SP SM5.0 500MHz, 1GB DDR5 3.2GHz 64-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : AMD Radeon HD 7570M (480SP 6C 500MHz, 1GB DDR5 3.2GHz 64-bit)
Compute Shader Processor : AMD Radeon HD 7570M (480SP 6C 500MHz, 1GB DDR5 3.2GHz 64-bit)
Storage Devices
Hitachi HTS727550A9E364 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 466GB (C:) (E:) (G:)
WDC WD3200BEVT-60ZCT0 (320.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache) : 298GB (D:)
hp DVD A DS8A8SH (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (F:)
Logical Storage Devices
SYSTEM : 300MB (NTFS)
My Passport (D:) : 298GB (NTFS) @ WDC WD3200BEVT-60ZCT0 (320.1GB, USB2/SATA150, 2.5", 5400rpm, 8MB Cache)
Hard Disk (C:) : 448GB (NTFS) @ Hitachi HTS727550A9E364 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
HP_RECOVERY (G:) : 15GB (NTFS) @ Hitachi HTS727550A9E364 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
HP_TOOLS (E:) : 2GB (FAT32) @ Hitachi HTS727550A9E364 (500.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Optical Drive (F:) : N/A @ hp DVD A DS8A8SH (SATA150, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : HP Panther Point LPC Controller
LPC Legacy Controller 1 : T1 07-01
Audio Device : HP Panther Point High Definition Audio Controller
Audio Codec : Integrated Device Tech 7605
Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem
Audio Device : HP Turks HDMI Audio [Radeon HD 6000 Series]
Audio Codec : ATI (AMD) HDMI Audio
Serial Port(s) : 3
Parallel Port(s) : 1
Disk Controller : HP Panther Point Mobile 6 port SATA AHCI Controller
Disk Controller : HP Standard SD Host Controller
USB Controller 1 : HP Panther Point USB xHCI Host Controller
USB Controller 2 : HP Panther Point USB Enhanced Host Controller #2
USB Controller 3 : HP Panther Point USB Enhanced Host Controller #1
FireWire/1394 Controller 1 : HP IEEE 1394 Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : PDF Complete Converter (2400x2400, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP ePrint (600x600, Parallel, Colour)
Sensors
Motion : HP Hewlett-Packard 3-axis Accelerometer (Motion, Accelerometer)
Network Services
Network Adapter : Intel(R) 82579LM Gigabit Network Connection (Ethernet)
Network Adapter : Bluetooth Personal Area Network (Ethernet)
Wireless Adapter : Intel(R) Centrino(R) Advanced-N 6205 (802.11g (ERP), AES-CCMP, 72Mbps)
Power Management
Battery No 1 : Hewlett-Packard Primary 58.43Wh/4.61Ah
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.3
Old 07-08-2014, 10:21 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Help (Frustrated) Play button works intermittently
Storage Devices
If you are recording to the WDC drive (D:) you'll need to replace it with a 7200rpm drive.
The Western Digital Caviar BLACK drives work very well (Higher the cache the better). Stay away from Green drives.
EDIT: Just noticed it's a laptop....not sure what drive options will be available to you.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 07-08-2014, 10:38 PM
Zedhed...Thanks. I'll check into hard drives tomorrow. Could that be the only thing causing it to hang? Seems like such a simple fix...coulda sworn there was a software/services conflict causing it.
Jim
Old 07-08-2014, 10:48 PM
zedhed's Avatar
I'm not sayin it's the only problem but it's the best place to start.
I remember back when I was using PT8 I had those sorts of problems until I switched the drive.
HD 96I/O
Music won't play. Play button flashes and Stop button lights up Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 04-16-2020 03:03 PM
Adding insert plug-ins only works intermittently cytokinesis macOS 0 06-24-2011 01:59 PM
Play start marker-frustrated jemukjs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2010 08:30 AM
Mouse click changes play button but won't play screaminbytes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-13-2007 10:13 PM
mbox, ibook, protools- sounds works intermittently vicsclipse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-22-2006 05:36 PM
