S6L feature request/ question
Several questions regarding the S6L user interface.... - is there any way to use spill+sends on fader mode combined fast from the universe view? (A different solution would be, that spill an Aux makes auto atically the send level on the fader and send pan on the encoder showing up instead of the ch fader level and ch pan for all of the channels, which are on in the particular aux) SSL did it with his "Query" function quite clever, as you can set up independently what should happen if you spill (well, "query") the Aux, the Stems (kind of subgroup) and the VCA. - Is there any way to switch to sends on fader mode for the auxes without soloing that particular aux? (Or even while soloing an another aux....??) - any way to use sends on fader the other way around? Meaning, the faders showing me, into which Auxes the selected input is sent to... (Midas, X32. SSL, Yamaha does this and it is quite usefull) All in all there is a need for "sends on fader" mode for all the input channels showing up, and also a different "sends on fader" mode, where only those input channels show up, which are switched on into the particular Aux. This together with the "reverse sends on fader" mode would ease the workflow for large IEM mixes extremely.... - any way to change/define the processing order in the signal chain for the input and the output channels? Most importantly the position of the plugins/ HW i sert points relative to the EQ, dynamics and pre or post Send postitions.... - sending mix busses back to mix busses would be just great! - for custom layers it would be great to make it possible to operate like the "profile mode" meaning, that the left 16 faders and the right 8 faders could be used and banked separately from the main 8 faders. This way you could make custom layouts for your input and for your output faders and bank them separately - similarly to the custom Layers, making custom rotary encoder layers would be great. In many different ways..... Here are really very large number of possibilities.... - on the touchscreens i can not switch on/off or jump to the ch inserts. Allowing this would be great. (With jumping to i mean, it could be still showing up on the external screen) - the bottom row of the external screen shows the current value I am changing, whatever it is. It was also the case on the Profile/ SC48 consoles. Now however the numbers are so small, that you would need such a big screen to see it good enough, that it would shadow the PA system from your ears literally!! Could it be made larger?? Thanks, Tamas Tako Hitsoundtech crew |
Re: S6L feature request/ question
FYI, one custom layer is available right now ("Channel").
Thanks,
That is something I am aware of But I mean also custom layout for the rotary encoders in the channel strip mode for example, and much more, as many people think many ways, so giving them the opportunity to customize the surface to their own kind of thinking/ workflow is something good I think Thanks, Tamas |
I would for example really like to se on the 4 rotaries gain, Comp threshold, Gate threshold and PAN when I am quiting from select Quote:
Anyhow, see the plugin details like you see the EQ curve on the touchscreen could be also an option, and so you wouldnt need to focus on the extrelan screen... Quote:
Thanks, Tamas |
Hybrid feature request plus question for other users | zerocide | Virtual Instruments | 8 | 05-30-2008 01:03 PM |
Feature Request+ question mark to 7.3 new features | 25ghosts | Pro Tools TDM Systems (Mac) | 16 | 12-15-2006 01:00 PM |
PT 6.1 feature request | Rob Macomber | Pro Tools TDM Systems (Mac) | 51 | 05-03-2003 11:11 AM |
Feature Request Question... | O.G. Killa | General Discussion | 4 | 10-22-2002 11:44 PM |
Feature Request | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-28-2002 12:08 AM |
