Re: "Problem detected with audio clock. Check that your clock source and sample......
This error is sometimes solved by using a different USB cable/USB port. If you have another cable around, try it. The other thing that I have seen cause this is a lack of power to the Mbox. Have you tried a powered USB hub?
Sign up for all things....AWESOME! Kris May the music move you |
Im getting this error in 8.03 with my Digi 002............Seems like an error....
a. Use 8.0.1 That fixed it for me.. b. Get ahold of 8.0.3 cs2 So far, I haven't had it crop up yet..
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Where do I get that from for LE for windows.......
If you have the white noise issues or just want to try 8.0.3 in a safer way...
They still may be offereing this... I don't know for sure. http://duc.digidesign.com/showpost.p...&postcount=375
#16
Thanks Tom.. I was gonna go and dig it out..
#17
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check clock source and sample rate are correct | mongrel8686 | Third Party Interfaces | 11 | 08-01-2013 08:42 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
Error: "Problem detected with audio clock. Check that your clock source and sample... | mongo_man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 05-01-2010 06:08 AM |
