Old 12-13-2004, 11:04 AM
Glenn75 Glenn75 is offline
Default Auto tune 4 vs. Pitch Doctor vs. PurePitch ect...
I need to find an effective easy to use pluggin for intonation and pitch correction. I need a pluggin that can correct problems on the fly for all instruments not just voice. I may need to use it for complex samples as well. What are the pro's and cons of each? I am leaning towards Auto Tune 4 because it seems to be the industry standard but are the other choices just as good or better? Is Auto Tune 4 the standard because of marketing or am I on the right track? Incidentally I already own Speed but it doesn't really accomplish what I am needing to do in many instances.
Old 12-13-2004, 11:32 AM
Craig F Craig F is offline
Default Re: Auto tune 4 vs. Pitch Doctor vs. PurePitch ect...
There is no perfect option. Auto Tune is the big dog in the game but I have seen Pitch Doctor work when Auto Tune just couldn't do the job.
The best plan is to have mutable programs.
All of them require tweaking so it won't be slap on and forget.
Thank you,
Craig
Old 12-13-2004, 12:04 PM
I'm not sure I understand what you mean by mutable programs. Can you explain?
Old 12-13-2004, 05:07 PM
Drew Mazurek's Avatar
I believe he meant multiple.
www.drewmazurek.com
Old 12-13-2004, 05:52 PM
tha k man tha k man is offline
Have you checked out Melodyne ? It can do some cool things too.
G5 Dual 1.8 /1.5 Gb Ram
OSX 10.4.7
PT LE 7.3 cs1
DIGI 002
Waves Ren
Sony Bundle
Soundtoys-arama
NI Komplete 3
Old 12-14-2004, 03:17 AM
crizdee's Avatar
crizdee crizdee is offline
Hello,
Since purchasing pitch doctor i rarely use autotue now! most of my tuning work is vocals and pitch doctor works better for vocals! an A/B test showed i was getting some chipmunk/cher effect with autotune and i wasn't getting this with pitch doctor.
Pitch doctor uses a whole processor chip? autotune uses 50% of a chip. i'll keep autotune for when i'm short of processing power.
Regards
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-14-2004, 08:18 AM
anodecathode anodecathode is offline
nudge the track back 80ms...
2009 Mac Pro Nehalem 2 X 2.26GHz Quad-Core Intel Xeon - OS 10.9.5 Mavericks - 128GB ram
ProTools TDM HD6 - Magma Expansion Chasis - PT 10.3.8 and Avid I/O.
ProTools 12.7.1.733
Macbook Pro 2.66GHz Intel Core 2 Duo OS 10.9.5
ProTools 12.7.1.733
Mbox2 PT 10.2
Scott Whittier
Whittier Creative
http://www.madmix.com/
www.voice123.com/scottwhittier
Old 12-14-2004, 03:47 PM
Snitz Snitz is offline
Pitch Dr. and Melodyne in tandem can yield really amazing results even in bad cases. Takes tweaking though, no doubt about it.....
AS
Old 12-15-2004, 01:15 AM
crizdee's Avatar
How you deal with long delay(80ms)?
Thanks!
80ms delay i can deal with! chipmunk on my vocals i can't!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-17-2004, 08:42 PM
So no Auto tune supporters? wow i'm suprised
Auto Tune & Pitch & Time on 7.1 PCI e & Quad TommyT Pro Tools TDM Systems (Mac) 0 12-23-2005 08:43 AM
Antares Auto-Tune 3 Pitch Correcting Plug-In Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-14-2004 04:50 PM
Pitch Doctor or Auto Tune LarryLatham Pro Tools TDM Systems (Mac) 14 02-24-2003 11:29 AM
best auto-tune, pitch correction, intonator? jon sutton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-04-2002 06:41 AM
Auto Tune or Pitch Doctor Ptrigs Tips & Tricks 1 05-29-2000 06:02 AM
