Old 09-18-2020, 02:07 PM
afterlight afterlight is offline
Default Completely baffled by HDX install
Hi there,
I'm trying to install an HD2 with two HDX cards. I have the Belkin cables and the original cabling from the HDX card boxes.
So...
If I put either card in slot 5 on its own, and connect the mini 6 pin to large 6 pin adaptor to it and then plug in the 4 pin, and connect my MTRX via digilink....it works.
The moment I put the second HDX card in slot 6, then....it will not detect the MTRX and says it isn't detecting the interface, won't allow me to open PT. If I open playback engine and select HDX it doesn't see anything, it allows me to select HDX but it's clearly not working.
This is with either card. If I put the second card in slot 4 and use the other power adaptor (8 pin) to connect the second card, won't load PT either.
How on earth are you meant to cable up an HD2? I'm not using any other PCIE slots for anything else, but slots 2 and 3, 3 & 4, 4 & 5...no matter what I try, two cards doesn't seem to work. But both cards individually digi-test just fine....
Old 09-18-2020, 02:32 PM
Default Re: Completely baffled by HDX install
I'm wondering if it has to do with something to do with the power cables? I've tried using both, using the splitter, every combination I can think of. It's so weird.
Old 09-18-2020, 02:43 PM
PS this is an install in the latest Mac Pro.
Old 09-18-2020, 03:05 PM
UPDATE.
Solved. Turned out to be a dodgy HDX card after all, a card from another rig worked fine.
Completely Baffled micheallsmith Artist Series 10 12-14-2014 12:08 AM
COMPLETELY Un-install Pro Tools 10 Win7 brianiac5150 Windows 10 03-25-2013 08:00 AM
Completely baffled here, no lie !!!!! shanabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-19-2007 04:39 PM
Hi im really baffled on this one... craiz730 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-11-2002 09:56 PM
Baffled, PLEASE Help Mearesy Digidesign Hardware & Software 2 04-12-2001 05:49 PM
