About to send project to master/replication
I was told not to place the songs on a cd as track 1 -15 but as 1 long track, is this correct, because some tracks I want to X-fade. The same place that master the cd will be replicating it. Is there a major differece between replication and duplication? |
Re: About to send project to master/replication
You say in the post title master/replication, which is it?
IF you are sending for mastering, check what formats your matering house accepts, most likely they will acept 24 bit protools sesions. Send them a CD of your mixes as DATA files in Protools. If you are sending off a mastered CD for duplication, again check the formats they accept, but what you want to send them is a redbook CD, 16bit 44.1k. The CD should be EXACTLY as you want it to be, including track gaps, index points, fade in/outs, levels, song order, etc. do not send as one long song, otherwise your CD's will have one track. Replication and duplication are synonymous terms. Mastering is an entirely different subject. |
Hi there MR808,
Replication= your CDR (must be in it's final, intended form)is encoded to an image, which is then used to create a glass master. After electroforming/galvanics they arrive at a stamper. This piece is used in injection molding to replicate up to 20-30.000 final CDs. A new stamper is created for additional production runs. This is the standard, professional and cheaper way ( in larger quantities )of manufacturing optical media. Duplication= simply put...your original source master> your CDR (must be in it's final, intended form)< is burned to any number of new CDRs. Just like you'd do it @ home..but differing degree of quality controll is employed. X-fade between tracks has nothing to do with numbering the CD tracks. However, a capable master editor should be used to create the final CDR ( Wavelab ?? ) hope this helps... cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
What format to send master out on. | RandyPokeda | macOS | 7 | 10-19-2012 09:12 PM |
How to view master level for bus SEND | Jperkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-17-2010 08:37 AM |
Project Mix I/O and Aux Send/Returns | adam79 | Pro Tools M-Powered (Mac) | 0 | 05-23-2007 02:15 PM |
Send it all to Aux before the master? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-28-2007 10:03 PM |
How to send a signal to several stereo buses with just one 'master' pan setting? | Jules | Pro Tools TDM Systems (Mac) | 10 | 03-05-2000 12:45 AM |
