Ctrl F/crossfades issue
Ctrl F is working for Fade In/Out but not crossfades. Don't know what happened. Was working then suddenly had limitations. Confident this is a settings issue. Any help would be muchly appreciated!
Thank you! Michael |
Re: Ctrl F/crossfades issue
It's possible that there is a very tiny fade already there, zoom in really close to the edit point to check. This has gotten me many times in the past.
Scott Gatteño |
Must be Windows. On my Windows machine, the system occasionally acts as if one or more modifier keys is stuck, causing commands that use those keys to stop working. Often, I can clear it by hitting the modifier key twice. But it tends to be only a workaround, for which the only fix is to reboot. I should note that my keyboard is an ancient PS2 type. Still works great, though I wonder if it could be the source of my problem. Maybe sometimes it fails to send the release stroke.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB Last edited by daeron80; 10-29-2020 at 11:35 AM. |
Crossfades issue | TMMusic | Pro Tools 10 | 4 | 05-17-2017 09:19 AM |
Crossfades distorting and export errors... Serious issue! | Arno Peeters | Pro Tools 12 | 1 | 01-03-2016 09:02 AM |
Issue when consolidate or AudioSuite crossfades | Jperkins | Pro Tools 12 | 10 | 07-01-2015 01:46 PM |
Ctrl+Scrub Wheel issue | kptkarl | ICON & C|24 | 6 | 11-03-2011 04:51 PM |
CTRL 24 Mac OS X Monitor Issue | MikeyK | Pro Tools TDM Systems (Mac) | 3 | 01-21-2009 09:45 AM |
