Old 12-02-2019, 05:33 AM
Default Slow High Sierra boot - solved
Just wanted to pass on a little saga I went through in case someone else might be having a slow boot up in OSX High Sierra. As some might know I run a dual-boot system with OSX10.13.6 and OSX 10.10.5. The reason being I had NI's B4II and Pro53 running there that wouldn't run anywheres else. I hadn't run either in a while, finally succumbing to NI's Vintage Organs and the B3 from Arturia and Arturia's Prophet 5/VS emulations. Had some downtime over the weekend and with the nasty weather rolling in here in the US Northeast I figured I'd wipe out the OSX 10.10.5 partition.
I run a 1 TB Samsung 850 SSD on a pcie card in the slot next to the video card in my 2012 cheesegrater.
That partition was the primary with the HS partition secondary. As any Mac user knows you cant' delete the primary partition so I reformatted it to APFS thereby wiping everything that was on there. To be safe before I started all this I made up to date clones of both partitions. So once I reformatted the partition I used Carbon Copy Cloner to clone over the High Sierra partition. Took about 45 minutes.
Rebooted into the new HS partition and tried a whole bunch of stuff to make sure everything worked. PT, rX7, everything worked okay. For safety's sake so I didn't lose my machine authorizations for my Waves stuff I moved the licenses to an old dslr memory card. The reboot took a while but then using the option key to boot into other than the usual partition takes a while so I paid no attention.
Once I was happy I deleted the old HS partition leaving me with one primary partition with HS on it. I then rebooted and it took almost two minutes to get to a working desktop after the startup chime. I'm used to maybe 20 seconds for that. Ran OSX disk utilitity's repair and it couldn't unmount the drive so I restarted from the external HS clone and ran disk utility to fix things. Rebooted into the normal internal HS and still slow. Googling this I came up with the thing of zapping the NVRAM which I did using this: https://support.apple.com/en-us/HT204063 and that did the trick.
Upshot is if you're having slow boot issues try zapping you NVRAM and see if that doesn't help you out.
PS: as a treat to myself for all that work I purchased the Shadow Hills Mastering Compressor plugin from Plugin Alliance. $99 US with code.
Old 12-02-2019, 06:39 AM
Sardi Sardi is offline
Default Re: Slow High Sierra boot - solved
Resetting the Parameter RAM is the first thing I do with any new Mac OS install. It even speeds up a fresh virgin install of Mac OS X.
I’m surprised you’d never come across that before. It’s quite a well documented fix for a lot of things.
Now run Diskwarrior on the drive and shave another second or two off. :)
Old 12-02-2019, 09:59 AM
Never had this kind of problem before. And the only time I ever had to zap the pram/nvram was years ago on my now dead iMac system.
And Diskwarrior won't work when rebuilding internal ssd's in OSX 10.13.6 which is what I'm running. This from their homepage. Besides shaving off another second or so isn't something I really need to do as I'm happy with the speed it boots at now.
Old 12-02-2019, 03:51 PM
Ah yeah. I forgot they STILL haven’t got DiskWarrior working wth APFS.
We’re onto the third revision of Mac OS that uses that file system so I really hope they get that sorted soon.
HDX driver is not available on fresh-boot High Sierra (2018.4) BoRiZ KukoBa Pro Tools HDX & HD Native Systems (Mac) 10 07-18-2018 11:37 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 09:30 PM
High Sierra yet? mlavin00 Pro Tools 12 18 11-13-2017 11:09 AM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 11:09 PM
"your computer restarted because of a problem" Sierra boot problem [SOLVED] reichman Pro Tools 12 0 02-22-2017 03:43 PM
