Old 03-03-2004, 12:14 AM
Renan Renan is offline
Default BUFFER SIZE PROBLEMS...
Sometimes PT LE drives me crazy... Why...?
Suddenly PT asks me to increase the buffer size... Ok... I do it... I set PT to "1024"... But, out of the blue (again) PT asks me to change the settings... But at this time, PT asks me to decrease the buffer... Then I set it to "512"... Then PT asks me again to increase... And decreasing once more... And increasing...
My system is:
Athlon 2.4
768 DDR
System HD 80 GB (C:) "7200rpm" NTFS
Files HD 120 GB (E:) "7200 rpm" FAT32
Files HD 80 GB (F:) "7200 rpm" FAT32
Video 32 MB PCI (my AGP slot is damaged)
DVD-recorder LG-4020B
AMIII card (PT LE)
Delta 2496 (others softwares)
Windows XP
So, what is going on...?
Please, I need somebody to help me...
Thanks in advance...
RENAN
Renan
Old 03-03-2004, 12:29 AM
KingFish KingFish is offline
Default Re: BUFFER SIZE PROBLEMS...
sounds like my girlfriend trying to make a desicion !
I really think it's your PCI video card - I tried to run PTLE with a PCI card for video, and it ran like crap, same sort of situation.
What's wrong with your AGP slot?
You can try to set windows to "Best Performance" set your display adapter at 16 bit, Load your Bios defaults, and try to free up IRQ's by disabling unused ports on your machine, USB, LAN, Serial, paralell, anything you aren't using.... and make sure the digi card is on it's own IRQ, swapping PCI slots if need be, but you've got to get rid of that PCI video card, it's killing you.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 03-04-2004, 06:52 AM
GdUb GdUb is offline
I have the same problem and my computer is 3 months old, everythings new exept the AMIII card. Maybe that's the problem.
Guy Dub
AMD 64 3000, 1,5G DDR, 460G SATA
ASUS A8V Dlx
ATI 9800 Pro
MBox
Pro Tools LE 7
Old 03-04-2004, 01:32 PM
Gil Lopez Gil Lopez is offline
Yes, I added a pci card to add a 3rd monitor and Pro Tools hasn't liked it. While recording the minimum number of samples in the playback I could have was 512. Otherwise I would get some type of a buffer underrun with some firewire error. It's a real bitch for latency issues. I really hate this because I want that 3rd monitor for plugins. The pci card is definitely fighting with the firewire pci card. Maybe it's a pci bus issue. I might have to give up that 3rd monitor.
Anybody out there running 3 or more monitors? What is your configuration?
-Gil
Buffer size problems(too little then too much) during recording nathanh26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2009 09:19 AM
Having problems with my H/W Buffer size The Poet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 06-13-2007 05:30 PM
H/W Buffer Size Problems soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 12-19-2006 04:11 AM
"H/W buffer size" pop-up problems mickj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-15-2004 08:39 AM
H/W Buffer size problems... Stingray74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-24-2004 01:06 AM
