Re: Recording vocals and Guitar in Reason or Pro Tools
And actually, if I can just speed up the track in PT without changing the key where the instrument plays at a higher pitch, then I don't even need to go into Reason. I just haven't figured out how to increase the tempo in PT without making the instrument play at a higher pitch.
I haven't used 7.4, but I know it has elastic audio. Set it to Polyphonic (or X-Form, if you have it), it should work.
Regarding Reason: Okay, well Reason 4 cannot use audio in the same way that most DAWs can. The only way to do this is to create either a NN-19 or NN-XT device. Import the audio file that you exported from Pro Tools. In the case of NN-XT, set it as middle C (NN-19 should make the root note middle C by default). Set the attack to lowest, hold and sustain and release as long as they can go. Now create a single MIDI note at velocity 127 at the start of your song. Reason only incorporated full audio functionality in version 6. Version 8 was released, and you can upgrade to it (from any other version) for $129. You should consider that, because the import would be as easy as drag and drop.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Nonetheless, thank you SOOO much for your valuable information. I just need to do a LOT of reading up on elastic audio, Rewire, and the NN-19 and NN-XT (which I don't normally use, sticking mainly with the combinator). Cheers! And I'll be back with a report on what happens! |
Here's my suggestion, assuming your end goal is to use recorded audio and Reason synths at the same time... ReWire does actually work well. Especially for this sort of thing, because samplers that load exceptionally long passages (such as the workaround I detailed in my post) can sometimes drift.. And playback is a pain, because in order to trigger the phrase, you have to start at the top every time..
https://www.youtube.com/watch?v=CT5NbuIqSRU Failing that, you can find a used copy of Reason 6.5 easily. It supports Win XP SP3, and has all the audio features you need for this particular project.
You, Sir, are awesome. And you win the internet tonight!
Recording Vocals With Pro Tools | BrianCeballo | macOS | 6 | 11-03-2014 09:51 PM |
Vocals Cutting out while recording in Pro Tools Le 8 | Endyga | Pro Tools M-Powered (Mac) | 0 | 03-11-2011 05:41 PM |
recording guitar and vocals simultaneously | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-09-2006 02:38 AM |
Recording vocals with Pro Tools, MIC GAIN> | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-21-2004 06:39 AM |
Recording Acoustic Guitar Duo/Vocals | gerax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-09-2002 11:20 AM |
