Old 08-11-2017, 01:23 AM
Raoul23 Raoul23 is offline
Default Re: Using Digi 003 and Kemper Profiling Amp
Kemper has to be master clock and are you using latest firmware on the kemper they released an update that sorted clicks on the SPDIF
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Lion 10.7.5 32GB Ram Magma PE6R4 Chassis
Old 08-11-2017, 06:13 AM
Alexrkstr Alexrkstr is offline
Hi Raoul, I have it as the master, connected with the proper spdif cables, with the latest 5.3.1 firmware.
15" MacBook Pro 9,1 mid-2012 15in 2.6HGz i7, 16GB RAM, OS 10.12.1 | OWC 320GB FW400 7200rpm
Digi 003 | PT 12.4
Old 08-11-2017, 06:14 AM
Originally Posted by Alexrkstr View Post
Hi Darryl - thanks again for the reply. Yes, I am using a set of 3ft long LiveWire SPDIF cables that are pretty much brand new. I've tested it with a third cable and the same annoying click/noise is present.
The setup for SPDIF works with the 11r, but I'm not sure what the settings that are making it work are (I'm running the 11r at 48kHz).
Interestingly enough... I had this exact problem with my POD HD Desktop and that's why I ended up selling it.
Yes but clicks when you are not clocking from the S/PDIF in are expected. This is not helping, you need to debug why you cannot clock from that. Set that up, confirm that is set in hardware setup, double check the session sample rate. Then if it is not working hot swap the S/PDIF cables, hot swap for another S/PDIF device etc.
Old 08-11-2017, 08:17 AM
FWIW, having recorded the Kemper thru SPDIF on a DIGI002 and thru a Chameleon Labs 581 mic pre, the analog path sounded much better
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Digi 002 and Kemper chopshop7777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-26-2016 11:04 PM
Inputting a Kemper Profiling amp into Pro Tools? ThrustTony Third Party Interfaces 8 12-02-2014 02:01 PM
This is crazy! Kemper Profiling Amp Benoni Eleven Rack 46 01-17-2013 07:29 AM
Kemper profiling amp?? Raoul23 Eleven Rack 18 01-08-2013 11:32 AM
Kemper Profiling Amp - Video Obsidian Dragon Eleven Rack 0 03-23-2012 06:17 AM
