Old 04-13-2021, 07:43 AM
paul_g's Avatar
paul_g paul_g is offline
Default Re: Playback Engine or Playback Ancient ?
Since I use both my UA Apollo (my main I/O device) and my Line6 HX Stomp, I too have to switch, close the session and reopen.
I could just use a pair of audio cables out of HX Stomp into my pre's, but Line6 does a nice job of running audio via USB. levels are already set, and I usually have HX Edit (their editor) open to make patch changes on the fly.
Also, things are very tidy. The HX is always connected to Mac via USB, one cable, not patch cables running everywhere.
Yes, would be nice to change the I/O Engine, I mean, Playback Engine without rebooting the session.
But, I will say after a length break (about 10 years) and formerly having an old mac with PT10, Now that I have my new Mac and PT200/21, I like now that I can play my music and video's without having to close PT to hear the audio! Nice touch!
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 04-14-2021, 07:43 AM
daeron80 daeron80 is offline
Originally Posted by huzzam View Post
closing and reopening most sessions takes about 3-10 seconds on a modern system.
Unless you're an orchestral composer with 30 GB of samples in RAM. I'm lucky if some of my sessions open in less then 3 minutes, never mind 3 seconds. And, yes, that's loading off of SSD.
David J. Finnamore
playback cuts out with plenty of CPU power left, have to change playback engine jmac146 Pro Tools 11 7 10-02-2016 11:34 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine keeps on forgetting my Duet USB Playback... plutopro Pro Tools 10 3 02-05-2013 12:42 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Playback Engine -- Where's my Disk Playback option? Wheeltard macOS 5 03-16-2012 06:19 AM
