Window 10 Update Results in Latency?
An Avid Support Tech told me today that the latest Windows 10 update on 2-26-19 is causing my Tascam 16x8 Interface to create playback latency (Overdubbed tracks are delayed during playback).
After many attempts to work through the problem, he now says the only thing I can do is wait for Tascam to come up with a fix and send out an update. Until then, I can't use Pro Tools to overdub. Does anyone have any knowledge or insights on this issue? |
Re: Window 10 Update Results in Latency?
I would try uninstalling the Tascam driver and re-installing(and would also download it fresh from the Tascam site) Then check 2 more things:
#1-system tweaks(especially Power Management on USB ports) #2-check Windows>Sound>Properties and make sure that Windows is NOT using the Tascam as its "Default Playback Device"(select the on-board sound card for that)
Pro Tools 9.0.5 Update - Eleven Rack Results | Benoni | Eleven Rack | 14 | 09-12-2011 09:46 PM |
Plasma & Canopus Latency Results | EarHole | Post - Surround - Video | 19 | 07-25-2006 07:55 PM |
Low latency Direct Connect gives same results | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-23-2002 09:39 PM |
Low latency direct connect gives same results | CCash | Pro Tools TDM Systems (Mac) | 1 | 01-20-2002 11:20 AM |
S/PDIF Latency & External Reverbs - w/ test results too | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 12-22-2001 12:46 AM |
