Old 10-30-2018, 06:23 PM
albertd67 albertd67 is offline
Default Problems with HD Accel Core Card
OK, this is weird: I thought I had problems with the software, but I'm starting to believe that is with the core card that I'm actually having those problems. I run PT HD 10 in my Mac Pro, and it runs smoothly, but when I add a HD Accel Core PCIe card, the program start loading and then get stuck right in the beginning. If I run Digitest, it opens but doesn't show the test window and then if I launch Pro Tools without quitting the not working Digitest, it opens and run normally. The "System Usage" screen doesn't show the presence of the core card. I need to mention that there is not interface yet plugged to the card (it's coming in a few days), but I don't think that's the problem. With no card, both Pro Tools and Digitest runs normally. Any idea?
Old 01-21-2019, 11:42 AM
Lightbulb Re: Problems with HD Accel Core Card
I am not confident that this is true. Whenever I launched a DSP-based version of Pro Tools (MIX, HD, HDX) without an interface powered up, the application would eventually ask me to power up an interface before it would finish launching.
More importantly, the Pro Tools v10.x installer requires you to select what your hardware is:
  • HDX or third-party
  • TDM
Since you were using Pro Tools without an HD Accel Core card, you were using a third-party audio interface. You will need to uninstall Pro Tools and then reinstall Pro Tools, during which you should have your HD Accel Core card installed and select TDM as your hardware.
PT HD1 (core card PCI) x PTHD1(Accel core card PCIE) Alécio Costa Pro Tools TDM Systems (Mac) 6 05-02-2017 06:52 AM
Digidesign HD3 Accel PCIe Core + 2 accel cards & 192 w/8 channel d/a output card juneaudio Buy & Sell 3 02-25-2015 12:45 PM
Using a PCIe core card as additional Accel card? Firechild Pro Tools TDM Systems (Mac) 3 07-30-2012 10:48 PM
Is every HD Core PCIe card an Accel Core Card? Matiz Pro Tools TDM Systems (Win) 3 06-11-2006 09:05 PM
HD Core card to Accel card flex cable in Dell 670 belouder Pro Tools TDM Systems (Win) 4 01-16-2006 07:55 PM
