Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 02-25-2017, 08:32 AM
grg1540 grg1540 is offline
Default Hardware Latency/Delay Compensation
Hey All,
When I route 1 audio track to my compressor so I can simply print it on a new audio track, I am experiencing some latency.
What the quickest most precise way of getting the new audio track exactly aligned with the original in the session? PT 10.
Yes I have searched online but looking for more info.
Thnx
Old 02-25-2017, 12:01 PM
Drew Mazurek's Avatar
Default Re: Hardware Latency/Delay Compensation
Originally Posted by grg1540 View Post
Hey All,
Thnx
You need to use Hardware Inserts so the delay can be compensated for. With HD and a Digilink I/O this happens automatically, with regular PT you need calculate and enter the delay in the I/O setup window.
Start by searching the manual for Hardware Inserts.
www.drewmazurek.com
Old 02-25-2017, 03:14 PM
That^^^, or record the processed audio to a new track and nudge it into alignment with the original track(show samples and SPOT the new audio according to a common transient). Advantage of a compensated input(as Drew mentions); Delay Compensation lines everything up fine(but off-line bounce is not possible). Advantage of recording and nudging; the processed audio is permanently added to the session, and once that's done, off-line bounce works
Old 10-02-2018, 09:50 AM
thigohdx thigohdx is offline
Hi there!!! What you’re saying is that with HDX/HD we dont need to calculate it? Any outboard?
Thanks
Old 10-02-2018, 03:12 PM
Thanks
HD/HDX with a Digilink interface.
www.drewmazurek.com
Old 10-02-2018, 03:44 PM
I have two digilink and two avid... Are the avid HD the same? Best!!!
Old 10-03-2018, 03:19 AM
So long as PT knows the box, you're good.
Which ones are they?
www.drewmazurek.com
Old 10-03-2018, 03:42 AM
Two Avid HD I/O 16x16
Two Digi 192 8in 16 out
HDX/pt ultimate
Old 10-03-2018, 06:03 AM
HDX/pt ultimate
Cool, you're good to go.
PT knows the delays with these boxes and will compensate automatically.
Keep in mind that you can only use I/O that are "stacked" on top of each other for Hardware Inserts.
See the Hardware Inserts tab of the I/O Setup page.
Let us know if you have any further questions.
www.drewmazurek.com
Old 10-03-2018, 07:12 AM
Please what do you mean by:
"Keep in mind that you can only use I/O that are "stacked" on top of each other for Hardware Inserts."
Best!
Analog Latency and Delay Compensation wedge Pro Tools HDX & HD Native Systems (Mac) 9 12-23-2011 12:15 PM
Latency, Delay compensation, Nudging Sergius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 08-28-2010 03:09 PM
Sample Latency and Delay Compensation RxdB Pro Tools TDM Systems (Mac) 5 08-01-2009 09:25 PM
LATENCY and DELAY COMPENSATION detroitkruk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-21-2006 11:36 PM
Latency/Delay Compensation and Rosetta 200 Ken K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-20-2005 03:15 PM
