Old 06-28-2019, 11:57 AM
audiobob's Avatar
audiobob audiobob is offline
Default Windows 10 1809
So I have version 1803 installed and see where 1809 is approved for PT12. I'd like to install it but only see version 1903 out there, which is not yet approved.
Is there an incremental update to 1809 available or do I just not worry about it and wait until Avid approves 1903. Just moved from Apple a while back and was pretty experienced. Still learning the Windows world.
Old 06-28-2019, 04:16 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Windows 10 1809
I'm on 1809 and 2019.6 W10 Pro with no issues, although I don't stress PT at all for my work.
Only issues I've had with Windows updates is having optimizations like USB Power Management and default Windows sounds/audio interface sometimes changing back to their pre-optimization settings. Just need to check and reoptimize the settings if/when needed.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-28-2019, 11:07 PM
sw rec sw rec is offline
Windows updates always re-enable my usb power management as well, and will occasionally wipe out my Matrox drivers, and install some crappy generic vga driver. Annoying, but fixable.
Old 07-01-2019, 02:25 PM
audiobob's Avatar
So where do I download 1809 specifically? I only see 1903, which I don't want. I know Apple has links to each incremental update. Something the same for Windows?
Old 07-01-2019, 02:43 PM
Nope, with Windoze you get what you get, I suspect.
Old 07-01-2019, 03:14 PM
BScout BScout is offline
Wrong
https://www.microsoft.com/en-us/soft...d/windows10ISO
Oct 2018 update is 1809
May 2019 update is 1903
Choose what you want. If you want further back you have to go into Microsoft's software depository. They don't make it impossible to get old versions unlike Apple.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 07-01-2019, 06:58 PM
YYR123's Avatar
YYR123 YYR123 is offline
Nice
Daniel
Old 07-01-2019, 07:27 PM
I stand corrected, and thank you!
Old 07-01-2019, 08:42 PM
The Weed's Avatar
Just out of curiosity, why don't you want 1903?
BTW, if you have Windows 10 Pro, use Group Policy Editor to completely turn off Windows Update. Sorry, no GPE in Windows 10 Home.
Old 07-02-2019, 01:42 PM
audiobob's Avatar
Avid has not approved 1903 so just trying to stay official. It may be working fine but I'm not experienced enough in Windows yet to take that chance.
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 2 05-07-2018 11:57 AM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire and USB Audio Interfaces (Win) 6 12-25-2015 03:40 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
