Automation on hidden tracks in the same Edit Group
I have some hidden tracks in the same Edit groups. Each time I want (for example) to automate the volume I have this message : "There are one or more hidden tracks in the same edit group(s) as the track you are currently editing. Even though these tracks are hidden their automation playlists will also be edited. Are you sure you want to continue with this operation." Then you can only "CANCEL" or "CONTINUE". Appart to show hidden tracks is there a workaround to not have this message? EDIT : Sorry I am on the Pro Tools Post & Surround forum (this is beacause I work in post, I forgot to change the area…). I don't know how to delete this message.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 10.14.6 - Ram 64G - PT Ultimate 2022.10.0 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) Last edited by yanos; 03-11-2014 at 06:49 AM. Reason: Wrong area |
Re: Automation on hidden tracks in the same Edit Group
Try checking the box in Preferences/Mixing-Suppress Automation "WriteTo..." Warnings
See if that does it.
Ray Trujillo Freelance Audio Engineer |
Thanks but unfortunately it does not.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 10.14.6 - Ram 64G - PT Ultimate 2022.10.0 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) |
Could it be helpful, as a workaround until it is possible to suppress this warning in the prefs,
to not hide any tracks of the group, arrange the track height of the "unwanted" (the formerly hidden ones) tracks of the group to micro, the track height of the "wanted" tracks of the group to fill the whole edit window, hide all other tracks and save this as a memory location (time properties to none , general properties to track show/hide and track heights) ? (will not work if there are too many "unwanted" tracks)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thanks Joachim, it could be a nice workaround with memory location !
Bruno |
I know this is a super old message thread, but it came up when I did a search on the issue. The solution is to go to the Groups pulldown menu and select 'Suspend All Groups'. This will allow you to make the changes without the warning message.
Automation on hidden tracks in the same Edit Group | yanos | macOS | 2 | 03-13-2014 07:41 AM |
PLEASE: button to edit HIDDEN playlists! | rtcstudio | Pro Tools TDM Systems (Mac) | 2 | 01-25-2012 09:57 PM |
Tracks Stuck as Hidden in Edit Window only?! | reichman | Pro Tools TDM Systems (Mac) | 3 | 10-16-2008 09:19 AM |
Should mixer/edit groups still work if tracks are hidden? | Ru_C | Pro Tools TDM Systems (Mac) | 3 | 01-25-2008 10:49 AM |
Can't I edit plug-in automation data simultaneously on grouped tracks (identical plu? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-02-2002 12:57 AM |
