Old 03-19-2020, 11:33 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Rolling Back O.S.
Yeah. I was a little interested about this so did some research. Have no T2 hardware here though, so cannot test.
Here's what you need to do, after you have created that bootable USB installer.
  • boot into recovery mode (command+R while booting)
  • in the menu bar, click utilities > startup security utility
  • select admin account and enter password
  • under "external boot" select "allow booting from external media"
  • close the utility and restart the computer holding option key
  • select your USB installer thumb drive
  • when it boots it'll say "software update is required to use this startup disk"
  • make sure you're connected to wifi, then select download. let it download. it will automatically reboot
  • on the second reboot, hold down option and select the USB installer thumb drive again
  • it will show the apple logo couple of times before the installer starts
This is how you should get your USB installer working with T2
Janne
Old 03-24-2020, 12:22 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Yes.
This is also needed for making external bootable clones.
Old 04-01-2020, 07:21 AM
jaglance jaglance is offline
Default Re: Rolling Back O.S. FWIW
Just rolled back a 2019 iMac to Mojave. No T2 chip. Had to use a usb 2.0 drive. For some reason boot drive with a 3.0 was undetectable
Old 04-01-2020, 11:19 AM
Sardi Sardi is offline
Yes. I’ve had this problem before too. Couldn’t for the life of me work out why.
Turns out, it’s dependant on the type of USB3 enclosure you’re using. If you do a web search you’ll find a bit of info pertaining to the issue.
Old 04-03-2020, 02:13 AM
markanthonybr markanthonybr is offline
I manage over 100 Macs for a University Music school here in London and just want to point out somethings from my latest experience:
1- the utilities security enable external boot only applied to Macs on sierra/ high sierra this wasn’t a necessary step with clean installs of Mojave it was an added security measure from apple in sierra/ high sierra.
2- If your mac is shipped with Catalina you wont be able to rollback to Mojave. This is based on my just having imaged 36 new mac minis in 2 of our mac labs.
3- target disk mode wont work using an original apple usbc cables only 3rd party cables still work. So carbon copy cloner running from an external drive worked fine for me.
4- Catalina will not make an older mac faster. Apples design model is to force you into buying new machines so I highly doubt the person who posted here that his iMac seemed faster because of the os update to Catalina is correct. He probably had improved performance from doing a clean install as wiping the disk and reinstalling will improve performance as bugs and permissions errors are put right or his mac was never configured properly. So I wouldn’t recommend that older mac users to rush into an OS upgrade based on that info.
Rolling back Mitch Griffin Pro Tools 12 7 10-07-2016 01:36 PM
Rolling back jeff5x0 Windows 4 05-01-2012 06:39 PM
Rolling back firmware on SYNC HD nasher99 Pro Tools TDM Systems (Mac) 1 12-02-2010 09:41 AM
>> Rolling back and forth between PT 7.3.1 and 7.4 Howardk Pro Tools TDM Systems (Mac) 3 11-23-2007 10:40 PM
Error after rolling back to 12.5 Pro Tools 12 0 12-31-1969 04:00 PM
