Old 01-24-2007, 01:35 PM
DJ FADE DJ FADE is offline
Default problems with bounce to disk - extra noise spike?
i'm trying to bounce a song, and i keep running in to problems with it. during each attempt to bounce, there will be one random noise spike added in. it comes in various places in the song, so its not in any of the audio files anywhere (i have double and triple checked). the noise doesnt play when in regular play mode in pro tools, only during the bounce. i am successfully bouncing other songs, just having trouble with one! ive closed/re-opened the session, shut down pro tools, even restarted the computer and its still doing it. i'm on ptle 6.9.
any help would be great!
thanks,
brandon
Old 01-24-2007, 03:31 PM
wolfskin wolfskin is offline
Default Re: problems with bounce to disk - extra noise spike?
Are you hearing the noise DURING the bounce, or when playing back the bounced file? Have you tried using the 'convert after bounce' option?
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 01-24-2007, 03:35 PM
lemix's Avatar
lemix lemix is offline
brandon,
Re-check your plug-ins, and give it a healthy top & tail space.
good luck,
a
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 01-24-2007, 03:59 PM
thanks for the replies.
i can hear it during the bounce and in playback after its completed. i usually select the option to 'convert after bounce'.
what would you check in terms of plugins?
Old 01-24-2007, 04:15 PM
JMS40 JMS40 is offline
Are you making a selection to bounce or just bouncing the session end to end?
If not, try it. Pick any track and manually select from a spot at the start to a spot at the end. Then bounce.
See if that helps.
"Convert after" works best for me.
Old 01-24-2007, 04:16 PM
lemix's Avatar
..that they are compatible w/your version of PT,
- if they don't "spike" your CPU..
try printing them before bounce, if too taxing.
a
cheers,
Andrew
Old 01-24-2007, 06:08 PM
i always bounce a highlighted selection, althought i'll try to make the selection a little longer on the front and end and see if that helps. as far as plugins, they should all be compatible, as they were all purchased and are used on many other sessions that have no problems bouncing. maybe i will try to print some of them to tracks to conserve some cpu processing and see if that helps as well.
in the mean time, any other suggestions?
Old 01-24-2007, 11:52 PM
If it's just this particular session, as you state, you might try importing the session data to a new session. I don't have an explanation as to why this session might be corrupt only when bouncing, but then again, I've seen stranger things
www.voodoopilot.com
Old 02-05-2007, 10:56 AM
peterkohl peterkohl is offline
I have the same problem running PT 5.1 on a Mac, but only when working in 16 bit/44.lk. And it only happens sometimes. My workaround is to change the length of the tail. I would like to know why this happens though.
Old 02-05-2007, 01:56 PM
Aussie169 Aussie169 is offline
Do you have any demo plugins in that session?
Some demo versions of plugins (Amplitube comes to mind) emit a burst of pink noise periodically so that you can't use them in an actual session till you buy it.
micing problems- extra noise lecherous Post - Surround - Video 2 08-16-2007 10:11 AM
Spike of noise at the end when I bounce to disk?? el biciclista Pro Tools TDM Systems (Mac) 15 12-21-2005 12:20 PM
Bounce to Disk - Getting "white noise" ansanity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-26-2005 09:39 AM
Bounce to disk--> white noise rjino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-06-2004 06:46 AM
Bounce to disk as mp3 - costs extra? eierdal Tips & Tricks 4 07-13-2004 10:40 AM
