Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 04-26-2018, 04:30 PM
Jperkins Jperkins is offline
Default Transferring Prefs
What's the best way now for transferring all my Pro Tools prefs from my main machine to my secondary machine?
For a few years I was using the PT Prefs app but I think it may be outdated because I get the MacOS warning about it not being optimized, plus it crashes when I try to make a prefs backup.
Does anybody have some tips of what folders I need to copy from my main machine and paste to my secondary machine?
I'd like all my plugin presets, channel strip presets, and as much stuff as possible to be transferred to my secondary machine.
Thanks.
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 04-26-2018, 04:35 PM
amagras amagras is offline
Default Re: Transferring Prefs
Trasher works on Mac now and it's only $5
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-26-2018, 04:36 PM
Thanks, I'll check it out.
Old 04-26-2018, 04:58 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Pro Tools Prefs
LATEST DOWNLOAD - V 1.6.20:http://duc.avid.com/showthread.php?t=340741
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both
(HFS+)
Pro Tools U-2019.12 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds/upkeep
New builds:
12 core nMP
16 core nMP rack
Old 04-27-2018, 02:53 AM
Pete Gates Pete Gates is offline
Which prefs app have you been using? Mine or the good old JC Deshaies one? If mine it shouldn’t be crashing Unless you have Pro Tools open at the same time - Pro Tools locks a couple of files that I need to work around. You shouldn’t be doing any backing up or restoring with Pro Tools open anyway though as there may be unflushed changes from Pro Tools.
Pete
Old 04-27-2018, 03:03 AM
The “not being optimized” message isn’t a problem, it’s just a warning that it’s a 32 bit application but that’s not an issue (yet).
Pete
Old 04-27-2018, 04:25 AM
I’m being dumb, you are obviously using mine as you’re on a recent version of Pro Tools. Are you able to describe how it crashes, at what part of the operation? I can have a look this evening.
Pete
Old 04-27-2018, 04:39 AM
Pete
Hi Pete,
I'll have to get back to you later today. I was remoting in to my main machine with Team Viewer to run the backup so I could Dropbox it to myself at home and install the prefs on my laptop.
It seemed to crash right after starting the backup process but got a little farther the 2nd time. Pro Tools could not have been open.
Here's a zip of the two crash reports:
https://www.dropbox.com/s/kgg8g0411f...JP_01.zip?dl=0
Later tonight I'll be back in and can try again. I've had good luck with this app before.
I know the optimization warning isn't critical yet but it made me wonder it f PT Prefs hadn't been updated to handle all the new things in PT 2018 like track presets.
Let me know if the crash reports tell you anything and I'll check in later.
Old 04-27-2018, 03:18 PM
It looks like I'm using the current version and it seems to constantly crash during the copying plugin settings process.
I attached some crash logs to my previous post.
Old 04-28-2018, 06:13 AM
Yup, I can reproduce it occasionally here now. Looking into it.
Cheers,
Pete
Is there a way to keep Pro Tools 10 Prefs separate from Pro Tools 11 Prefs? DJ Hellfire macOS 5 11-17-2014 02:27 PM
Transferring Prefs to another computer Jperkins Pro Tools 11 12 10-27-2013 09:57 PM
PT Prefs.. MoritzRock Pro Tools TDM Systems (Mac) 6 03-05-2008 03:17 PM
No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs bigthinka9 Pro Tools TDM Systems (Mac) 6 10-24-2002 07:41 AM
AS prefs? - and thanks Noiz2 Pro Tools TDM Systems (Mac) 3 03-22-2001 09:54 PM
