Old 11-18-2010, 12:02 PM
Raoul23 Raoul23 is offline
Default PT 9HD equivelent
Just purchased pro tools 9 and i have a 003r+ what would i need to get the quality or near enough the same quality as PT HD as obviously i dont have to use the 003 any more and the convertors in these are just ok and not brillant
Im using windows 7 so i know i cant use an apogee coz if im correct they only work on a mac
Thanks
Old 11-18-2010, 12:04 PM
Brandonx1 Brandonx1 is offline
Default Re: PT 9HD equivelent
I'd go outboard converters with the 003 or an RME interface. RME cheap, stable and great sounding
Old 11-18-2010, 12:47 PM
sorry what do u mean outboard convertors,
do you mean connect the RME to the light pipe connection
sorry if im sounding stupid
Thanks for the info
Old 11-18-2010, 03:11 PM
MJarzabek MJarzabek is offline
I agree with Brandon. You can buy nice outboard mic pre's with great AD converters then send the signal over light pipe (ADAT) to the 003. Just make sure you sync the 003 and mic pre together with SPDIF, word clock, etc. so there are no artifacts in ADAT signal.
Still working.
Old 11-19-2010, 01:25 AM
Perfect thanks for your info ill start looking for convertors/pre's now
Thanks
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 11-21-2010, 12:11 AM
mickeymassacre mickeymassacre is offline
http://blacklionaudio.com
I loved what I have heard.
Old 11-21-2010, 08:27 AM
noeqplease noeqplease is offline
Location: Lake Arrowhead, CA, USA, Planet Earth, Solar System, Milky Way Galaxy
Thanks
When you say "quality" what are you referring to exactly?
If it's the audio conversion and playback quality, then yes, you need to look at different converter units.
What's your budget?
Nick Sevilla
[email protected]
Old 11-21-2010, 09:51 AM
drumster drumster is offline
If you really want to step up your game in the conversion department then I'd highly recommend the Lynx Aurora 8. You'll need the LT-ADAT card installed on it, so you can hook it up via ADAT to the 003. Then connect a BNC cable to the word clock connection on the 003 and clock to the Lynx. You're looking at about $2225.00 for this option, so it really depends on your budget.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
[IMG] code is Off
PT LE equivelent to DP humanize theremin Tips & Tricks 3 12-04-2006 08:09 AM
VST EQUIVELENT graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-21-2001 12:17 AM
