Old 12-22-2011, 12:18 PM
SeattleHank SeattleHank is offline
Default Bounce to Disk issues and bounce to direct show error.
I could use some advice or suggestions.
I am running Protools 10.0.0 on an HPZ400.
In the first case I have imported a .wmv video with audio. It seems to import fine. I can process and sweeten audio as needed. But when it is time to export/bounce back into a final .wmv file I have two issues.
First: When bouncing direct to disk, I end up with a .wma (Audio only – no video) even though I am selecting the windows media option? Any suggestions? I am only bouncing a single stereo audio track with the imported video.
Second: When I bounce using the direct show option, it gets all the way through the processing then spits out the following error. “Could not complete the Bounce to Disk command because Access Violation occurred, unable to read location: 0x00000004.
Can anyone clue me in as to why I am getting this error?
Thanks!!!!!
I just want to render my work!!
Old 07-08-2012, 09:26 AM
xeligio xeligio is offline
Default Re: Bounce to Disk issues and bounce to direct show error.
Hey,
I am having the same problem. Did you managed to sort it out?
Old 07-11-2012, 07:31 AM
EGS's Avatar
EGS EGS is offline
Thanks!!!!!
Hmmmm... Before you bounce, are you selecting the portion of the timeline you wish to bounce (step 5 below)? I'm not sure what the solution is, but you might want to read the topic:
Bouncing a Video Track with
Windows Media Video to a
WIndows Media Movie
on page 1194 here:
http://akmedia.digidesign.com/suppor..._v10_73478.pdf
Hope this helps !!!
Click for audio/video demo
Click for resume
Old 08-10-2012, 11:51 AM
Scharc5150 Scharc5150 is offline
I'm having exactly the same issue as described above. Has anyone found a solution to this?? Thanks
Old 08-13-2012, 02:54 PM
SteveD@DAWPRO SteveD@DAWPRO is offline
Be sure to check sharing and security tabs of the folder containing the project and audio files.
Insure that all users have "Full Control" rights to the folders.
This not only solved this problem for me, but Pro Tools 10.2 became rock solid on both my studio rig and my laptop.
Hope this helps.
SteveD
www.DawPro.com
...addicted to gear
Old 12-31-2013, 12:19 AM
MarkCollins MarkCollins is offline
I am having the same problem trying to bounce a video - get all the way done then I get the - could not complete bounce to disk command because access violation occurred, unable to read location: 0x00000004 - message
Is there a fix ?
Mark
[email protected]
Old 12-31-2013, 12:20 PM
mesaone mesaone is offline
What kind of video (codec, container)?
Old 01-01-2014, 12:41 PM
Bouncing a windows media file
PT 10+ - Windows 7 - 16 gig mem -- very fast computer and have no other issues except with bouncing video - though I am new with working with video and pro tools
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
bounce to disk issues MusicLOve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-21-2011 12:59 PM
Bounce to disk error - pro tools won't let me bounce the file! HipHopHead Pro Tools M-Powered (Win) 1 05-14-2009 11:13 AM
Midi from K2000 to show up in Bounce to disk? influenceaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-15-2004 02:51 PM
Bounce To Disk or monitor out direct to ext. CDR? KennyD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 08-13-2001 07:24 PM
