Old 02-17-2021, 12:28 PM
daveotero daveotero is offline
Default Eucon issues after Cubase 11.0.10 Update
Anyone else have issues after this latest Cubase update?
My Dock and S1 are much slower to respond and things like adding tracks, deleting tracks, and moving tracks cause the whole system to freeze up for sometimes over a minute, often resulting in the Eucon service crashing. Everything was fine before the Cubase update so I'm guessing they broke something, but my control surface is unusable for now.
System:
Windows 10
Cubase 11.0.10
Eucon 2020.11.1.10
Old 02-17-2021, 01:21 PM
Vex One Vex One is offline
Default Re: Eucon issues after Cubase 11.0.10 Update
I'm using the Artist Mix as opposed to the S1 but I haven't notced any issues after the update.
P.S. Since you're also a Cubase user, do you mind chiming in on my post regarding fix requests?
http://duc.avid.com/showthread.php?t=414127
Old 02-18-2021, 08:19 AM
EddieJones's Avatar
It should be OK.....you could run the EUCON installer and chose to remove all apps and remove all prefs, reboot and install EuControl Again to rule Avid out.
s1&dock&eucon issues with Cubase 10.5 anason-records Avid S1, S3, Dock and Control App 11 02-20-2024 10:27 AM
Anyone have Eucon xml for Cubase Pro 8.5? Rpro System 5 7 05-14-2018 04:50 PM
Cubase 8 and Eucon? dkean Artist Series 6 05-03-2015 07:08 PM
Cubase 8 and EuCon mesaone Artist Series 2 04-22-2015 08:43 PM
Cubase 5.5.2 And EuCon 2.5.6 dvrooman Artist Series 2 11-10-2010 12:20 PM
