Old 08-03-2016, 12:44 PM
sellout sellout is offline
Default Avid Video Engine Was Unable To Stop - is this an on going joke?
Since PT5.0, it use to be you drop an mov in and you get to work.
So do I understand correctly, that avid no longer wants us to be able to execute work that requires video on protools?
Why does it suck now, after working near perfect for so many years?
Old 08-03-2016, 01:24 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Avid Video Engine Was Unable To Stop - is this an on going joke?
Video is working fine for me in 12.5.2. What type of mov are you importing?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-03-2016, 01:30 PM
I have been using the recommend codecs on avid site.
DNxHD (Preferred)
Apple ProRes 422 (including HQ, LT and Proxy) - did not use this one.
DV25
DV50
H.264 (Performance may vary)
I will try out 12.5.2
Old 08-04-2016, 06:49 AM
john1192 john1192 is offline
Video Engine .. i have not had any issues with videos playing but i have with the video engine starting up .. it can be very slow ..
i have used H.264, Pro Res LT with no issues once the AVE is running .. there have been some video issues for a bit now but they seem to be getting resolved a little at a time ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-04-2016, 08:33 AM
How about some more info about your rig, software versions, etc? No way to help without knowing more. If you're on 12.5, and you're having issues it's unlikely that 12.5.2 will fix it - more likely something else dicey in your configuration.
No issues here.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-04-2016, 02:16 PM
TrentWilliams TrentWilliams is offline
Tips for a problem free video session.
- Use DNxHD, or DNxHR codecs at 8bit
- Display video track in 'blocks'
- Use right click on the video window to select your predefined sizes. (Don't use free scale to make the window bigger or smaller).
- Make sure you have selected 'best performance', and 'lowest quality' in the video track settings.
If you follow these, I promise you, you will have almost no video engine troubles.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 08-04-2016, 07:47 PM
Led Led is offline
Looping very short sections with video can cause this to happen too.
Old 08-05-2016, 01:53 AM
soybalm soybalm is offline
It stopped here too, but lowering the resolution helped immensely. 12.5.2 PT 10 works flawlessly on all resolutions.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
"The avid video engine was unable to stop" error hbadger30 Pro Tools HDX & HD Native Systems (Mac) 20 10-01-2019 03:51 AM
Avid Video Engine Was Unable To Stop EdwardG Pro Tools 12 11 07-27-2016 06:26 AM
AVID Video Engine unable to stop 12.5 mattrixx Pro Tools 12 8 06-17-2016 01:32 PM
Video Engine is a joke!!!!!! nayrbnoswal Post - Surround - Video 31 05-11-2015 03:46 AM
Video engine keeps playing after I stop Schottlandru Windows 0 09-22-2014 03:09 PM
