midisport 8x8 locks up my system
Well,
I just upgraded my system to the amd dual core 4800 and premium mobo, with 2G of ram and 2 Sata drives. I figured I'd put my Midisport 8x8 to the test and I recorded some midi and sure enough, it locked up again. Of couse I had to reboot the system and start over. I got an updated driver a while back from the maudio site and hoped that would cure the problem but I guess it didn't. I went back to the midi ports on the rack unit and I haven't had any problems with it so far. Though, I need a few more midi outs or I'd be content to use it. Has anyone else had any problems with a midisport 8x8? Is there possibly something on the unit that I'm not configuring correctly or something? Thanks for any help.
AMD dualcore 4800. Asus premium, 2Gs, 80G Maxtor, 250G WD 3.0G/s. Triton and Pod Rack. Midisport 8x8. Samson 16 rack. |
Re: midisport 8x8 locks up my system
Hey Johnnie, I had the same problem when recording with my Triton. I dont think your problem is with the 8x8. Not sure what instruments you have hooked up, but I beleive your receiving a looped midi signal, which crashes your session, causing you to have to reboot. Might want to try and change the MIDI Thru setting on ProTools. If that dont work. You have to trace that signal. Find out which instrument is causing the problem by recording one at a time and do a process of emlimination.
Good luck - I just gave up on it. Cant get the Triton to stop sending the signal. |
Xpand! just locks my system up!!!! | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-08-2006 03:17 AM |
My system locks up! HELPPPP! | rparts1 | Pro Tools M-Powered (Win) | 2 | 08-31-2005 10:42 AM |
xp system locks up on launch | legendaryoak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-11-2004 06:16 PM |
system locks at start up | angryd | Pro Tools TDM Systems (Mac) | 1 | 07-20-2001 06:10 AM |
Waves 2.9.1 locks up my system | pnoise | Pro Tools TDM Systems (Mac) | 0 | 10-09-2000 07:36 AM |
