Will not get past launch screen
hey guys, I downloaded pro tools first and I cannot get past the launch screen, it loads up the plug in and all that but it freezes at the Initializing the Audio Engine section during startup. then eventually says that pro tools is not responding then crashes. I'm lost. my laptop is a HP with the i5 processor 8gb RAM and 1TB memory.
Pretty sure we can help you out here, but we need more info. Starting with what exact windows version are you trying to use?
Unfortunately Pro Tools First is poorly designed for new users and you have to be following the install documentation. Like http://akmedia.digidesign.com/suppor...uide_85130.pdf but even that documentation is awful and does not cover basic stuff about windows audio drivers. And with all the limitations with Pro Tools First I would usually recommend people use full Pro Tools or another DAW. What audio interface/playback engine are you hoping Pro Tools will use? Did you install device drivers for it? If the laptop built in audio what exact device is it? (E.g. In Windows device manager and sound manager... post screenshots of those if you are lost). Hold down the ‘N’ key while Pro Tools is starting, when the playback engine dialog appears what exact options does it give you in the pull down selector. Last edited by Darryl Ramm; 05-23-2018 at 12:59 AM. |
Re: Will not get past launch screen
I'm using Windows 10 personal, I'm using the default playback and default recording mic built into the computer, it is the Realtek Audio devices. I've tried holding down N when booting the program to no avail. I will mention that when I first downloaded the program PTF it worked great the first 5 or 6 times I launched it then it just stopped working.
The Realtek Audio devices have no ASIO driver. ProTools requires ASIO-compatible audio hardware on Windows. That's your problem -- Pro Tools has no audio hardware it can use so it is getting stuck.
You can make the Realtek Audio usable by installing ASIO4ALL http://www.asio4all.org/ And configuring it. Then the Realtek audio can be an option (not a good option) for Pro Tools to use.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I actually have ASIO4ALL installed and was trying to use it for my CAD AUDIO USB microphone and that's when the problem started
It is absolutely unnecessary to use ASIO4all. The WASAPI windows driver works just fine. The problems occur when you are trying to use the audio engine for multiple things(internet videos, media player, etc) Pro tools wants exclusive use of the windows audio engine and becomes problem prone if you try to make windows sound multi-task. Also Pro Tools on windows does not like to see ANYTHING in the DVD drive, so make sure no media is mounted. Check your sound control panel settings, especially sample rate and bit depth under preferences, advanced as media player or browser may have changed settings on you.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
64GTOBOY- there is no media in the drive. I checked that lol where do I go from here?
Seems a pretty clear cause/effect relationship.
So what can I do to possibly fix it?
I have since went back to using the computers microphone and it still crashes at launch btw. I couldn't get ASIO4ALL to allow me to select the USB mic on pro tools
Protools Control App won't go past the login screen | JCBigler | Avid S1, S3, Dock and Control App | 14 | 04-04-2017 02:29 PM |
Pro Tools 10 won't get past loading screen | rgp101 | Pro Tools 10 | 7 | 06-05-2015 10:50 AM |
Pt 11.1 will not load past splash screen | Norrie | macOS | 15 | 01-15-2014 08:29 AM |
003 will not launch PT past DigiRewire.dpm | Playmusicdamnit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-03-2008 02:11 PM |
003 will not launch PT past DigiRewire.dpm | Playmusicdamnit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-02-2008 06:20 PM |
