Old 03-09-2014, 09:44 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Default HDX Latency
Now there's two words that shouldn't appear together...
Anyone else experiencing latency issues when monitoring in record mode? I'm finding them once the track counts get up past 16, or the voice counts pass 25. This is HDX (one card), Avid HD, DigiPRE, and nothing else that's particularly special. You can see my specs below.
It seems to be triggered by HDX-able plugs, for example the Softube Grand Channel. It's a pretty annoying little delay, probably 3 or 4 frames. (Not sure what the ms correlation would be.)
I never had any kind of problem like this with TDM. Seems very strange, and I'm not so happy about it, either!
Old 03-09-2014, 09:52 AM
Drew Mazurek's Avatar
Default Re: HDX Latency
You're positive there are no native plugs in the session, on auxes, or master faders?
Have you done any "double assigning"? (holding down control while clicking to assign an output to 2 places)
www.drewmazurek.com
Old 03-09-2014, 10:33 AM
Nope. Setup couldn't be more straight ahead. Now 30 minutes down the road, I'm tracking BGVox on some existing tracks with no plugs, and the latency is back. Once I recycle the record switch on the track, it goes away until I start playing again. It doesn't appear to be recording late (I clapped to check that) but the monitoring is really annoying. Working alone today to suss this out, have singers in on Tuesday.
Old 03-09-2014, 10:34 AM
Wait, hold on. Yes there are Native plugs in the session. Not on the tracks in question but in the session. Why should that matter? It's supposed to run both, right?
Old 03-09-2014, 01:32 PM
Yes, but if they're on Aux or Master Faders, they cause the whole thing to be delayed.
www.drewmazurek.com
Old 03-09-2014, 01:53 PM
Hanswurstlsepp Hanswurstlsepp is offline
Exactly !
Beside that, I'm running into a "situation" once a while where the "talent" is telling me "something's wrong - there's a delay".
My workaround for that is to disable ADC and enable it again.
Helps in about 70% of all cases.
If it won't help, save session, close session and reload.
...and if that won't help, quit PT completely and restart it.
Awesome
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 03-10-2014, 09:19 AM
Drew, maybe you know something I don't, but are you saying that a native plug in on an Aux track anywhere in PT can cause delay on the record track that isn't at all related to that native plug? How can that be? And we're not talking about general, garden variety, subliminal delay, we're talking "screw-you-up," "can't work with this" delay. I don't use MSTR faders, BTW.
I do use AUX tracks to host my reverbs/FX, etc. and feed them from those tracks, of course. And some of them are DSP, some of them are native, I mean, there's no getting around that in this brave new world. But the presence of native plugs in the whole of the session shouldn't cause this kind of delay.
The other responder is hearing what I'm hearing I think. When the singers are saying "something's not right..." yes, that's it. Wow. This is bad!
All I have to compare it with is 10 years of HD|TDM and I've never had this problem. It's pretty unthinkable!
Old 03-10-2014, 09:20 AM
Originally Posted by Hanswurstlsepp View Post
Exactly !
Awesome
You're saying that disabling ADC solves the problem? Wow, that's bizarre. I'll try it, though.
Old 03-10-2014, 09:48 AM
Disabling and enabling again .... not just disabling
Cheers, STeff
Old 03-10-2014, 09:49 AM
Same here. Started with HDX !
Cheers, STeff
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Piano VI's- Latency Latency!! MARVINBASS Virtual Instruments 5 04-27-2006 01:09 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
