Old 09-27-2020, 05:28 PM
Siegfried Meier Siegfried Meier is offline
Default TDM Amp Sims
Hey all!
I'm trying to figure out if there's any TDM Amp Sims besides the most obvious ones in my list:
1. Eleven
2. Waves Gtr
3. Amp Farm
4. Chrome Tone
We still use several HD rigs for tracking guitar DI's, and usually turn off the cabs and use TL Space with all the various cab sims out there for tracking...sounds quite awesome. It would be best if the Amp Sim could be used for mixing on our newer rigs, and the first 3 of that list are available as new AAX plugins.
Thanks!!
Sig
Old 09-27-2020, 10:24 PM
Default Re: TDM Amp Sims
Just a note... Eleven Mk II has TDM and AAX support, you might have meant that, but just be sure, it gets you a handy set of extra amps... and amps compatible with the Eleven Rack... folks may want to track through that, so more reason to use? I'm pretty biased towards Eleven, the only other sim I use is BIAS FX/Amp, native only of course. Native it works fine, and on a TDM or HDX systems if you "reamp" those native while mixing...
Old 09-28-2020, 03:08 PM
What?!? I had no idea!! So, do I automatically have a license for mk2 TDM if we have mk2?
Old 09-28-2020, 03:16 PM
I see a 12.3 and an 18.1 and an 18.8 installer...which one would I use for Pro Tools 10HD?
https://www.avid.com/plugins/eleven-mk-ii
And my license says it has 3 plugs in it - Mk ii, Eleven LE and Eleven...that would ensure that it works as TDM?
Old 09-28-2020, 03:40 PM
I tried installing the 12.3 version...def nothing TDM here, and there's no AAX Native version either...are you sure this works?
I'm on HD10 with Mavericks.
Thanks!
Sig
Old 09-28-2020, 03:41 PM
JFreak's Avatar
JFreak JFreak is online now
Yes, the original Eleven (non mkII) is TDM
Janne
Old 09-28-2020, 05:05 PM
Yes, we all know that...Darryl above is saying Mkii was TDM as well though...can someone confirm?
Old 09-28-2020, 05:36 PM
JFreak's Avatar
mkII is AAX-only, but sounds identical to mkI
Janne
Old 09-28-2020, 06:35 PM
Ugh sorry. Thanks Janne.
What a dick. I thought Mk II was TDM as well. And I swore I had Googled to check that before posting, I have no idea what I looked at to convince myself that was true. I'm just an Eleven and Eleven Mk II fan boi. There is something just easier about dialing them in and getting a more realistic tone than other amp sims I've tried (certainly between Eleven Mk II and say Bias FX 2.. which I also like)
Old 09-28-2020, 06:43 PM
Ahhh bummer...got me excited there haha.
Are there any other TDM amp sims anyone else can think of?
Thanks!
Sig
Cab and Mic sims live 1960lespaul Eleven Rack 5 07-13-2014 01:56 PM
HDX No more DSP Amp Sims roberts macOS 9 01-09-2012 10:38 AM
Cab sims on one output but not the other? MJ Slaughter Eleven Rack 3 04-22-2011 04:39 PM
Best Amp Sims? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 08-14-2009 12:48 AM
Amp Sims and order of EQ and plug-ins Premo Tips & Tricks 5 03-02-2009 03:37 PM
