  #281
Old 01-05-2021, 01:32 AM
grfrgr grfrgr is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Showing the possibility of using Lemur to control Pro tools without memorizing shortcuts?
  #282
Old 01-05-2021, 03:37 AM
Oliver M Oliver M is offline
Oh, I see.
I used Quadro for this, unfortunately they are out of business.
Are you happy with Lemur?
  #283
Old 01-06-2021, 02:00 AM
Very Happy, it's very customizable, it sends midi to Keyboard maestro which then runs the scripts.
  #284
Old 01-19-2021, 12:31 PM
oudi oudi is offline
i use lemur with osculator
it's perfect....
you can put directly your applescript in osculator ...
  #285
Old 01-19-2021, 03:31 PM
it's perfect....
Great advice, thx Oudi!
  #286
Old 08-29-2021, 09:11 AM
its2loud its2loud is offline
I need some AppleScript love from the community.
I'm use this and similar scripts to execute Audio Suite plugins.
tell application "System Events"
tell process "Pro Tools"
set frontmost to true
if exists (window "Audio Suite: iZotope RX De-click") then
click UI element "render" of window "Audio Suite: RX 8 De-click"
else
click menu item "RX 8 De-click" of menu of menu item "Noise Reduction" of menu "AudioSuite" of menu bar 1
end if
end tell
end tell
The script runs perfectly when I execute it in Automator. The problem is when I assign a shortcut key to execute the command. So say I implement (Command+F16) to execute. What ends up happening is the script will run but the RENDER button will be "clicked" three times. I can't figure this out for the life of me.
I'm running OS 11.4
PT 2021.7
Mac Mini M1
I appreciate any help. I'm pulling what's left of my hair out.
  #287
Old 08-30-2021, 01:14 AM
else
end if
end tell
end tell
I'm running OS 11.4
PT 2021.7
Mac Mini M1
it is probably the shortcut you are using, I used FastScripts and assigned F19 to the script, it works fine. Have you tried anything else but cmd+F16? Also check if you have assigned the shortcut to anything else already, like Automator, Keyboard Maestro, whatever.
  #288
Old 08-30-2021, 06:10 AM
Thanks Oliver,
I have tried a few different keyboard combinations that aren’t being used for anything else that I know of. I do have keyboard maestro on the system.
I try just a straight up Fkey and see what happens. Maybe if I have keyboard maestro trigger the service that will work.
Appreciate the feedback
  #289
Old 08-30-2021, 06:26 AM
What happens if you run the AppleScript from within an AppleScript Editor (Script Debugger or Script Editor)?
I don't wanna put the blame on Keyboard Maestro but I gave up using it in combination with AppleScript files (compiled Scripts or ScriptBundles) and Automator is a little slow. Give FastScripts a try just to see if the issue persists. FastScripts can be used free for up to 10 AppleScripts, worth a try.
  #290
Old 08-30-2021, 06:33 AM
The script runs fine through the editor. Originally I was doing a system keyboard shortcut for the service. You think KM was messing that up?
I’ll try FastScripts and see what happens. Thanks!
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
