#2241
Re: Best Core 2 Series Desktops-Results and Specs
Its strange that you are getting such low scores when OCing. I am currently running Q6600 at 2.86 (9*318) and Dverb score is up by 30%. Maybe its the ram?
as for your questions 1. no 2. IMO there is no advantage to running 1:1 oposed to other ratios. Just make sure your RAM stays at or below its specs. 3. It varies (probably about 75-80 would start seeing issues) but I personally don't feel cofortable running anything abouve 65. I have tweaked my system to stay below 55 on full load. 4. The bottleneck seems to be your RAM. If anything replace it with DDR2 1066 5,5,5,15. Its really cheap these days
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#2242
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#2243
#2244
Thanks mano111 & mykhal for your advices.
I downloaded DVERB1 v7.3 and OC to 3.2GHz (8*400) and got 292 DVERB. Now, will this: Kingston HyperX 2GB 240-Pin DDR2 SDRAM DDR2 1066 Desktop Memory Model KHX8500D2/2G boost my rig performace? This chip can 5-5-5-15 with overclocking! |
#2245
#2246
Questions for Benchmarking (comparing apples to apples )
1. In PT8 should I use 32 Audio Tracks and start using Aux or 48 Audio Tracks? I tried both and found that using 32 Audio Tracks then Aux gave more D-Verbs than 48 Audio Tracks. 2. Can I set my Protools CPU usage to 95% instead of 90% 3. Am using 1024 buffer and not 2048. Is this correct? 4. Should I leave the Elastic Audio turned on (by default) on all audio tracks? thnx |
#2247
2) yes 3) yes 4) yes
#2248
Thank you mykhal for your help.
Now comparing apples to apples! 310 Dverbs on Q6600 OC to 3.2GHz (8*400) 4GB RAM 800 [with extra plugins installed] CPU Temp 52 @ full load! EDIT: 265 Dverbs on Q6600 stock speed 2.4GHz (9*266) 4GB RAM 800 [with extra plugins installed] CPU Temp 45 @ full load! |
#2249
excellent you'll see a gain if you choose to go with the DDR2 1066 ram. either way, nice job and happy Toolin'!!
#2250
So my final results are (solid tone for 5 minutes): 265 Dverbs on Q6600 stock 2.4GHz (9*266) 4GB RAM Kingston PC6400 800 310 Dverbs on Q6600 OC to 3.2GHz (8*400) 4GB RAM Kingston PC6400 800 344 Dverbs on Q6600 OC to 3.2GHz (8*400) 4GB RAM Kingston PC8500 1066 |
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
