Old 05-30-2020, 05:16 PM
Media Man Media Man is offline
Default consolidating tracks into a single file
Or better question .. how to "un-consolidate a track into it's original form before it was consolidated.
So I create a consolidated file out of many segments on a track, and then a couple days and several other edits later, realize I made a mistake.
Is there any way to revert back to the condition of a track with in it's editing and patched-up configuration before it was consolidated? If I "clear" the consolidated track there is nothing on the track. If I look in the clips window there are billions of clips with that track number, most of which were not included in the consolidation and a nightmare to try to reconfigure.
Any ideas? Am I missing something obvious?
Media Man
Old 05-30-2020, 05:34 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: consolidating tracks into a single file
Hi ! I think you can't undo that unless the consolidation was did recently so you can simply use the undo command te revert. Maybe checking the in sessions backup folder an older session with the unconsolidated track ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 05-30-2020, 06:46 PM
That's what I thought.
It would be a nice feature to be able to "revert" any consolidated track or shorter file to it's original source regions. I can remember many instances I wish I could do that. Or somehow in the clips list, have an option to see what parts the whole was made of.
Thanks,
Media Man
Old 05-30-2020, 08:29 PM
Sardi Sardi is offline
Unless you need the audio as a single file to use outside of PT, why don’t you region group the audio on the timeline instead.
It will appear as a single block on the timeline and all the fades etc. will be hidden and active. You can still use clip gain etc.
Might be a better solution for you as you can ungroup the region at any point and redo an edit.
Old 05-31-2020, 07:15 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by Media Man View Post
... Is there any way to revert back to the condition of a track with in it's editing and patched-up configuration before it was consolidated? ...
Duplicate track to a new playlist, and then consolidate. To go back, just bring back previous playlist.
Click for audio/video demo
Click for resume
Old 05-31-2020, 08:35 AM
Playlist *everything*! I playlist every step of the way when editing/pitching/timing/denoising - that way there's always a trail of breadcrumbs if you need to get back to a previous state.
Also, what about saved session backups prior to the consolidate? You can just import the pre-consolidated track.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-05-2020, 11:25 AM
That's what I did. Just reloaded one of the auto backups.
Of course. Duh.
Sometimes the easiest solution is the last one to come to mind.
Media Man
Old 06-05-2020, 11:26 AM
Yes, this needed to exported out of Pro Tools, but then I heard an edit mistake that needed fixing.
Old 06-07-2020, 01:45 PM
Sparky1 Sparky1 is offline
Do this routinely... 👍
Sparky
Import single midi file of a keys track from logic opens multiple tracks in PT alfalaschi Pro Tools 12 2 04-10-2017 07:15 PM
consolidating file with crossfade bug? francois Pro Tools 11 4 09-02-2014 07:18 AM
Consolidating file Southern Prince Pro Tools M-Powered (Win) 1 02-24-2009 07:58 AM
Copying single tracks from one file to another new file Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2008 11:55 AM
Multiple CD tracks from single file ThB Music Digidesign Hardware & Software 0 09-15-1999 10:54 PM
