Old 11-29-2019, 07:32 AM
EdwardG's Avatar
EdwardG EdwardG is offline
Default Protools 12 and 2019.10 Co-installation.
Well title says very much it...
Pro tools .app has been renamed so it wont be replaced with the new one, is the 2019 installation doing much more than just replacing the app? does anybody know if there could be any incompatibility that would render pro tools 12 unusable? we are in mojave 5 by the way.
thanks in advance
UPDATE: (pun intended)
A AVID guy gave me the answer, yep pro tools installs more files elsewhere other than the .APP file, but in theory shouldn be a problem, and remembered me that old workspaces don't load in newer pro tools. all good, thanks!
Old 12-01-2019, 01:34 AM
Ale Ale is offline
Default Re: Protools 12 and 2019.10 Co-installation.
Hi
I always rename protools in finder manually befor install new versions so I do not erase the current installation. THat way I keep the last version runable on my computer.
A new version of Protools always also installs new versions of its plugins.
But I never hat problems running new versions in older protools versions.
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 12-01-2019, 04:31 AM
Originally Posted by Ale View Post
Hi
Ale
I've got 2019.6 and 2019.10 on my Mac. The only thing is if you open PT by clicking on a session .ptx file it will open whatever is the last PT version to be installed - at least it did here on OSX 10.13.6. Since I want to have sessions opened with PT 2019.6 I did a 'get info' on a session, changed the 'open with' to PT 2019.6 and clicked the little box that says to open all such files in my choice.
I don't know if you can do similar in Windows or not.
Jack
QAPLA!
Protools 2019.10 installation fail MacOS 10.13.6 bsteeve Pro Tools 2019 8 11-04-2019 05:38 AM
2019.10 installation error cmbourget Pro Tools 2019 9 10-31-2019 09:55 PM
2019.6 strange installation errors... WKG Pro Tools 2019 1 07-21-2019 05:59 AM
11R and ProTools 2019.5 jjnssn Eleven Rack 0 06-02-2019 07:18 PM
0 can`t right error since PT 2019 installation, Good Job Avid spock999 Pro Tools 2019 0 05-16-2019 11:50 AM
