Problem With Recording Vocals in Pro Tools
Hi everyone. I'm new to the forum and new to home recording. I have a Mbox Mini 2. This weekend I wanted to record a song with some of my vocals on it. I imported a midi file into Pro Tools and was able to pick the instruments through Reason and got all the instruments on the track.
When it came time to record my vocals, I set up my microphone (MXL 990) in my closet and attempted to sing. When I listened to the track, it sounded really thin and it didn't capture any of the low end in my voice. It also sounded grated, distorted, and scratchy, and frankly my laptop microphone sounds much better than the recording with the MXL 990. I have a full baritone voice, and the recording I made basically destroyed all the fullness of my natural voice and turned it into something very thin and weak sounding. I must be doing something wrong, because the reviews I've read on the internet about the MXL 990 make it seem like it's a decent starter microphone. I'm running a 15 foot XLR cable from the microphone into the input 1 on the back of the Mbox Mini 2. I have the Mic/DI and Pad buttons out, and the 48V button is pushed in. I tried pushing the Mic/DI button in, and nothing recorded. The same thing happened when I pushed the 48V button out. This mic requires phantom power, so I believe that pushing the 48V button in engages that power. From there I am recording right on to a Pro Tools Audio Track. I tried switching the microphone to an SM58. This sounded better and more full, but I know that you are supposed to use condenser microphones for vocals on recordings. Please help me with recording vocals through my MXL 990. |
Re: Problem With Recording Vocals in Pro Tools
Well, if the 57 sounded OK thru the same setup, then about the only two possible culprits I can think of are 1) the MXL is defective, 2) the mbox phantom power is weak, voltage dropping too low. Recording in a closet isn't necessarily the best idea, either, unless it's a pretty good sized walk-in. You might do better in your room. All those clothes can swallow up a lot of the sound and make things sound lifeless.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks for your comments. |
Did you ever stop to think that maybe the 40$ mic you purchased is the reason it sounds thin? I had the MXL and I've since upgraded thru a few different choices and the difference is night and day. The mxl will be very thin w/ not much low end. Might wanna check into a nicer condenser
Yeah, I agree with my bros, you're gonna have to shell out more than 50 bucks for a good sounding vocal mic. But on the other hand MXL does make some good sounding microphones. I have one of their tube mics that sounds like a $1000 . But this is for your vocal, you wouldn't buy a 49 dollar guitar would you? Take it back, check out the Rhodes, AKG C 3000, (my favorite $300 mic) or at least the MXL 4000. You'll be glad you did.
Oh and BTW, a good cord can make a HUGE difference! |
MBox2Pro / LE 8.0.5 |
Try plugging the mic into other inputs on the M-Box.
I would do that to rule out an issue with a defective input. Not sure how the M-BOX is set up, but on my 003, the phantom power applies to pairs of inputs, not each one. If this is the case with the M-BOX, try another input with a different phantom power button. I agree that a $49 mic ain't gonna sound that great. But, if you have the same issue with the 58, it might be something else. A 58 should work reasonably well, but will not give you the richness of a good condenser.
----------------------------- Wango Don’t piss down my back and tell me it’s raining. http://www.soundclick.com/bands/defa...?bandID=851389 |
Static Problem when recording vocals | Filmmaker123 | macOS | 0 | 10-20-2012 07:33 AM |
Having a problem in Pro Tools when recording vocals | musiclovin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 01-09-2010 09:20 PM |
Problem with recording vocals in Pro Tools 8 | Abdul Aziz | General Discussion | 2 | 02-27-2009 05:00 AM |
Problem with recording vocals in Pro Tools 8 | Abdul Aziz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-02-2009 10:05 PM |
Problem recording vocals!!!Help!!!Delay!! | dmt2828 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-11-2007 12:14 PM |
