Old 03-28-2024, 11:37 AM
stevegalante stevegalante is offline
Default PT loses midi connection
Weird problem with PT Ultimate 2024.3.0 (on Win 11), it seems to lose midi connection.
All of a sudden no midi goes through PT, but my master keyboard and the midi box (Midiman Minisport 2x2) are still communicating properly.
The midi track is rec armed, red flashing but when I play the keyboard nothing happens.
Closing and reopening the session doesn't change things, I just have to reboot PT.
Any ideas ?
Thanks !
http://www.stevegalante.com
Old 03-28-2024, 11:49 AM
massivekerry's Avatar
massivekerry massivekerry is online now
Default Re: PT loses midi connection
Any ideas ?
Thanks !
Check the Track's MIDI Output to see if it's still routed to the correct VI or device. Sometimes the assignment gets lost (it's a bug). Beyond that, some VIs have needed to be updated to pass data properly. Or the MIDI volume is turned down/off (check CCs for MIDI Volume -7 or ModWheel -1)
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 04-13-2024, 06:15 PM
Benny_Cha_Cha Benny_Cha_Cha is offline
I’m having a similar issue on Ventura w both 2023.12 and 2024.3. It is an issue at the midi server level. Same as op, basically all midi stops working on all devices. I can see my midi interfaces getting signal from external controllers. Was working fine in a session then just stops working. Restart required to get it working again. And then sometime not for very long. Yet another issue pushing my towards Logic.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 04-14-2024, 03:03 PM
Update: Restarting the MidiServer via Activity Monitor seems to work to avoid having to restart after PT crashes, which is EVERY TIME I use MIDI.
Ben Rubin
benrubin.com
S1 loses connection Jazzbass56 Avid S1, S3, Dock and Control App 24 01-30-2020 10:18 AM
pro tools loses MIDI connection with 002 Rack kw88keys Pro Tools 11 2 09-19-2015 09:32 PM
002R loses connection 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-07-2008 01:31 PM
002R Loses connection w/PT LE 7.3.1 badseed79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-09-2007 10:17 PM
001 loses connection mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2004 08:47 PM
