playback cursor disappears when looping separate edit & timeline selections
to illustrate take a look at the 2 screengrabs.
both have separate edit & timeline selections (ES & TS) and playback is set to loop. the problem is that when the ES is earlier than the TS (pic A) the playback cursor disappears whereas in the pic B situation ie ES later than TS - it appears & behaves as you would expect. Also PT forgets to loop the ES sometimes too and playback just sails past the end of the ES so what's that about? I am using the square bracket keys to switch between the ES & TS. Is this supposed to happen or is it a glitch? is there some other setting i am missing? Does this happen on a mac or later versions of PT? i am using PT LE 8.05 on win 7 64. thanks. edit: in fact it seems the playback cursor needs a bit of encouragement to move across the screen when using loop playback generally eg stopping playback and re-starting can get it moving again. i haven't tested it with fully with markers yet. has nobody using LE on windows encountered this glitch before ? maybe its a graphics card thing but i've never had a problem like this in any other daw. Last edited by Calon; 02-07-2014 at 02:55 PM. Reason: extra info |
Re: playback cursor disappears when looping separate edit & timeline selections
Looks like "like timeline and edit selection" is off A little box under the tools bar looks like up and down arrows and left right arrows together. chris
which will loop separately. the point i am making is that the playback cursor disappears when an ES is earlier than a TS but not when an ES is later than a TS. i would be interested to know if anyone can replicate this. edit: in fact there doesn't seem to be any logic as to when looped playback occurs when u have separate edit and timeline selections although timeline selections are more consistently looped. In any case I don't see any reason why the cursor should freeze or disappear other than it being a graphics glitch. Last edited by Calon; 02-07-2014 at 03:12 PM. |
In PT 11.1.2HD, the playback cursor across all tracks is displayed when playing back. Does not matter, if the ES is earlier or later than the TS. I believe, in stop there is no blinking cursor because PT does not know yet, if it should playback the ES or TS.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
ProTools Edit Window Disappears With Soundminer Spot to Timeline | chadjhughes | macOS | 1 | 02-25-2014 06:51 AM |
Separate link timeline and edit selections | KimSira | Tips & Tricks | 1 | 06-01-2010 02:43 AM |
Question about ProTools looping playback in timeline - minimum length required? | natez311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-21-2010 10:13 PM |
Wider or thicker timeline/edit cursor | stratquebec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2009 10:29 AM |
Timeline and edit selections | meathman | Pro Tools TDM Systems (Mac) | 0 | 05-10-2007 07:51 AM |
