Old 12-11-2012, 04:19 PM
djmichaelwenz djmichaelwenz is offline
Exclamation Eucon connection bug or issue with Mackie Control
Ok, I am hoping someone here can help me out. I am on Windows7 64. I had ableton working using Mackie Control wonderfully. Now somehow something is preventing it from starting right away without a tweak. I think something is running or the service needs re-configuration.
After having Ableton working so well, I went to test out Cubase with the MC control. I didn't have channels 1-8 available as it is assigned to Ableton so I removed my addition of cubase using the control panel icon. Now when I open Ableton that has Mackie control that was working great it does not have transport control working. The only workaround I have found is to add another app using the control panel eucon icon. I would add ableton again and then delete it. Open ableton and then all would work as usual. I have all these soft keys programmed and I am afraid of loosing them if I reinstall. I get it working and the same problem occurs when I restart the pc. I think I need to kill a process or something. Anyone out there have a clue? Thanks guys!!!
System: GIGABYTE GA-X58A-UD3R LGA 1366 FF
CPU: Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor BX80601950. Dual Boot SSD Win7 and Yosemite.
Located suburbs Milwaukee, WI USA
Need Analog Mastering? I have 15 years experience. www.WenzMastering.com
Old 12-11-2012, 07:08 PM
Default Re: Eucon connection bug or issue with Mackie Control
Yeah not even pro tools transport works when rebooting...I have to enable Eucon in pro tools again after reboot. Please will saving a layout stay if I reinstall?
Old 12-11-2012, 07:42 PM
Forgot to mention, when I change or add eucon app while ableton is open I get BSOD Everytime... Pro Tools did come back with transport control this last reboot. Times before though I know I had to re enable it.
Old 12-11-2012, 08:01 PM
I am tempted to re install it but I dont want to loose my layout... Ughh
wait found this
http://avid.force.com/pkb/articles/e...211?popup=true
Old 12-11-2012, 09:08 PM
I guess I fixed it with wiping out the installation and the folders and then reinstalling and restoring my layouts. I think I am goo now. That was lame
Old 12-13-2012, 07:53 PM
UPDATE
Ok, I cannot seem to get this to work without having to switch Mackie Control Assignments around before starting Ableton.
How can I wipe this out and start fresh?
I am now very frustrated as it was working perfectly. Its like I have to re assign it before launching. No mater what I do or what channels I assign ableton too I have to change it before entering. I just need to remove all Euphonix registry stuff and whatever and start fresh I feel. Help. Super annoyed!
Old 12-18-2012, 07:51 PM
Ok seems like I have to have Eucontrol active when booting or logging in to have it remember to connect to Ableton. Works fine if I do that.
Whats weird is that it used to be Mackie Control 1-8 and now its only 1-4 Any Ideas Anyone?????????????
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Connection Pb of Mackie MCU Pro with PT LE7 on WIn XP salkazanov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-27-2007 06:17 AM
Mackie Control Losing Connection with 002r RobDahne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-28-2005 10:52 AM
Mackie Control lose connection?! mbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-14-2003 09:17 PM
Can the Mackie Control extender work w/o Mackie Control? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2003 08:52 AM
