Old 02-04-2012, 12:53 PM
paulrgmusic paulrgmusic is offline
Default Audio Clock issue
Hi
Whenever I close one session and open another, I get an error message as soon as I press play. It pauses for a second and then tells me there is an audio clock error and I need to check the audio clock and the sample rate. I can't see anything wrong with them (I always leave it on 'internal' as I have no external stuff to keep in sync). If I go to the hardware settings and try to change the HW buffer, I'm told that PT cannot reacquire the hardware as another programme is using it. Then it tells me that PT must close due to an unknown error and that PT is not installed!
Any ideas? I have made sure no other audio apps are running (as far as I know) so I don't know what the issue is.
System is in signature. I now use PT10.0.1 and Mac OSX 10.7.3 although this issue started when using PT10 and OSX 10.7 so I was hoping that the upgrades might put things right somehow.
Thanks
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
500GB G-Drive Mini (FW audio drive)
Mac OS X 10.7.3 (Lion)
Pro Tools 10.0.1
Mbox 2 Pro (connected by FW)
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
mp3 audio clock issue the_dr38 macOS 2 02-17-2012 02:43 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
Audio clock issue blogduc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-15-2010 02:50 PM
Newbie needs help with audio clock issue Gobblet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-20-2007 12:00 PM
