Old 12-13-2011, 08:54 PM
robertg robertg is offline
Default Eucon commands not stackable?
Hello, when defining buttons in Logic Pro, I can create one Eucon command on a button, then the option for eucon is greyed out when I want to create the second. Is this on purpose? I'm able to stack standard keyboard buttons, however.
Old 12-14-2011, 12:05 PM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Default Re: Eucon commands not stackable?
I don't think you can launch a series of Eucon commands. I'm not sure why you would do so anyway as they have very precise functions...
Is this a theoretical question or are you trying to achieve something in particular?
Old 12-14-2011, 09:26 PM
Programming macros is supposed to be a major feature highlight of the Eucon products, it's even in the demo videos.. In this case, I want to set locators to region size, turn on cycle mode, and play - with one button
Old 12-15-2011, 12:43 AM
You can launch any series of keys however before or after a Eucon command and mix them with wheel, faders, project specific and page functions.
Anyway, you do not need Eucon commands for either play (obviously Space) or cycle (C). You could even assign a shortcut in Logic for the location function.
An example of something you can do with Eucon and not with any other protocol:
Change faders layout (ex: to strings) with a Mc command while simultaneously jumping to a proper Screenset (key shortcut), and playing back (key shortcut) from a marker (Eucon project specific) for the strings section. You could even change to a different touchscreen page (Page) simultaneously and trigger a series of other key functions.
It's very powerful, but if your making a complex macro it's useless to use the Eucon command for "play".
Old 12-15-2011, 09:58 AM
Actually, it isn't useless at all because there are some functions in logic which are dependent on window focus. The nice thing about Eucon is that it triggers functions on the "back end" without certain windows having to be in the foreground, etc.. Play and cycle are not obviously, however others are..
Plus, when stacking commands, now the only way is to find your first command in Eucon the usual way, then you have to switch over to key commands in logic to figure out what shortcut is the default, assign it if necessary, etc.. a pain, would be better to do them all in one place. Making the Eucon section searchable would also be nice.
Old 12-15-2011, 10:15 AM
I understand, but the possibilities of conflicts between commands are enormous, that is probably why you can only assign one Eucon command.
EuCon Commands missing from Editor! TimNielsen Artist Series 9 10-27-2016 06:36 AM
Can I use a maco with 2 eucon commands? Brandonx1 Artist Series 3 04-07-2012 07:54 PM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 02:35 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
