Old 04-28-2011, 01:36 AM
dlmstudio dlmstudio is offline
Default Venue SC48 and PT8LE
Hi there,
I'm preparing a live recording of an orchestra, and want to use the Venue SC48 in combination with my MacPro/Digi003Rack/PT8LE setup.
I only have one shot to get things right (the orchestra plays only one concert) and have to hire the Venue SC48 (so I don't have that much time to try stuff out).
I already did some live FOH gigs on Venue's, so I'm familiar with operating the desk from the mixing point of view.
But concerning the use of the SC48 with PT8LE I want to know:
1. Are there any softwareversion-issues I should be aware of?
2. Can I have BOTH my 003Rack AND the SC48 running on the same Mac at the same time? (so I can have 24tracks available for recording)
3. Will one iLok key (mine is in my MacPro) be ok?
Any other "do and don't" 's on this matter are very welcome, as I don't have much time to try things out (and the mic count is already 42, and rising...)
Thanx in advance!
Old 04-28-2011, 07:04 AM
mariojorgeandrade mariojorgeandrade is offline
Default Re: Venue SC48 and PT8LE
Maybe you should rent a PTHD/Venue Mix Rack/HDx rig, instead.
I believe you can only aggregate audio interfaces if you were using PT9.
So, with a SC48, you're limited to 18 channels only.
If it's the only way, you can record the main channels using each channels' direct outs and grouping the others to auxes or groups.
And don't forget to turn the direct outs on, and to adjust their level at the patchbay tab.
It's really easy.
Good luck.
Regards,
MJ
Old 05-03-2011, 09:16 AM
Thanks for your advice, MJ.
In the meantime I figured out a routing for which I only need 16 PT channels,
so I think the SC48 will do for the job
This will require some on the fly live mixing, but hey, we've got to keep things a bit exciting as well, eh?
Greetings,
mon
PT10.0.1/Venue SC48 Al Rettich macOS 0 05-07-2012 02:24 PM
New webinar: Meet the VENUE SC48 Remote System, Stage 48, and VENUE 3 bobcats VENUE Live Sound Systems 2 03-24-2012 07:35 AM
Just got our Venue SC48 ionStorm VENUE Live Sound Systems 0 03-10-2010 02:52 AM
Venue SC48 and Pro Tools LE Justin Bartlett VENUE Live Sound Systems 37 08-04-2009 05:23 PM
VENUE D-Show 2.8 Standalone Software for VENUE SC48 Avid VENUE Live Sound Systems 0 05-13-2009 12:30 AM
