Old 10-24-2006, 02:35 PM
highcard highcard is offline
Default Command8 Faders don\'t follow MIDI track automation
Hi
I have just upgraded to ProTools LE 7.1.2r2, MBox 2 Pro and Tiger on a g5 1.8g dual. The faders on the Command 8 no longer follow the volume automation on MIDI tracks. If I click in the track, the fader will jump to the position of the automation, but the faders don't follow the automation during playback. Works fine on audio tracks. Anyone know how to fix this? Is this a bug in the release? Firmware update? Help please. Mixing MIDI tracks was a big reason for buying the Command8.
Thanks to anyone who knows an answer to this one.
Here is the even weirder thing - I just noticed the problem only starts happening around 6 minutes into a session
UPDATE: I have now noticed the problem goes away if I put the MIDI tracks into "sample" mode instead of "ticks"
Old 12-19-2006, 11:34 AM
kRokksOn kRokksOn is offline
Default Re: Command8 Faders don\'t follow MIDI track automation
Please post a bug report to Digi, that´s how things get fixed.
If we all help to make the system better we´ll all be a lot happier:)
Good luck.
"lyrics, wasted time between solos!"
kiddipalli@simnet.is
syrland.is
myspace.com/kiddipalli
Faders and FX automation by Midi keyboard AmitSadras Pro Tools 10 4 01-22-2012 10:19 AM
Command8 Control 24 faders question Dot Pro Tools 9 4 09-28-2011 06:20 PM
automation mode buttons/C8 channels follow track-selection automatically clusterer ProControl, Control|24, Command|8 2 11-24-2009 03:16 PM
How to - C8 faders to follow a click on a track - ?? Samuel Axelsson ProControl, Control|24, Command|8 3 09-12-2008 02:05 AM
