Old 03-25-2012, 11:13 AM
paulrgmusic paulrgmusic is offline
Default Clock Source Error - General question
Hi
After trawling the DUC archives, the general consensus about how to solve the Clock Source/Sample Rate error seems to be "nobody knows".
I have no problem with this and am always grateful for any help I get on the DUC so I wonder if someone can answer this:
Is this likely to be a software or hardware issue?
If I use the built in sound (and take the mbox 2 pro out of the equation) it works fine, the error goes away. With the mbox plugged in, any time I open a different session, I run the risk of the error coming back (about 50% of the time it comes back).
I did a reinstallation of PT10 yesterday and I have all the suggested things in place regarding power settings, wifi off, time machine off, prefs trashed, disk permissions reset and I still get the issue when I have the mbox connected.
If I need to buy something new, I can live with that. I just don't want to spend a few hundred quid on something to plug it in to find it has no effect.
I'm going to try and borrow a different interface and see if it makes a difference but if anyone has any info which may be useful I'd love to hear it.
Thanks
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
500GB G-Drive Mini (FW audio drive)
Mac OS X 10.7.3 (Lion)
Pro Tools 10.0.1
Mbox 2 Pro (connected by FW)
Old 03-25-2012, 11:29 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Clock Source Error - General question
In hardware setup you definitely have it set to internal clock yes?
And none of the inputs in the hardware setup are set to digital?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-25-2012, 11:40 AM
lexaudio lexaudio is offline
Sounds like the clock source is set to spidf.
Old 03-25-2012, 11:54 AM
Hi
Thanks for the replies. The clock is definitely set to internal (both in PT10 and in the Pref Panel) and I have no outboard gear at all. I had spdif available but not used in the IO so I've unchecked them just in case.
There are many posts from users with this error but there are never any solutions.
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
Pro Tools 10.0.1
Old 03-25-2012, 12:02 PM
Try changing the USB cable.
Old 03-25-2012, 12:11 PM
I'll have to dig around and see if I've got a different firewire cable but I'll give it a shot.
Cheers
Paul
2011 27" iMac
3.4 GHz i7
12GB RAM
Pro Tools 10.0.1
Old 03-25-2012, 12:16 PM
If you are getting clock errors not related to a digital input, it is likely the connection from the host to the interface.
Try blowing dirt and dust out of both ports as well, and change the firewire cable.
Try using a thicker FW cable as well. Those thin Apple cables I don't trust.
Old 03-25-2012, 12:56 PM
Thanks again, I'll try those things too.
2011 27" iMac
3.4 GHz i7
12GB RAM
Pro Tools 10.0.1
Audio clock source error Lynnweb7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-29-2011 10:22 AM
Internal Clock Source Error and Midi Problems with Vista sean13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-04-2010 03:42 PM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
newbie clock source question gracec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-12-2009 08:20 AM
PT 7.1 M-PWD FST TRK USB - CLOCK SOURCE/SAMPLE RATE ERROR cjprough Pro Tools M-Powered (Win) 2 04-15-2008 09:48 AM
