PT11 is shutting down my Windows PC
Since I downloaded PT11 I have walked away from my Windows 7 SP1 PC and came back and found that my PC has just shut down and one time when I was sitting right in front of the PC, Its happened 4 times now and only when PT11 was up and running, anyone else have this happen?
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Re: PT11 is shutting down my Windows PC
Shut down as in shutdown normally? Shut down as a BSOD? Or a hard reset as a motherboard protection event?
Some how I accidentally downloaded and installed 003 Rack drivers for my 003 console. In conjunction with the transformer on the utility pole directly across the street exploding just as PT11 launched for the first time. It made for a exciting and stressful troubleshooting session. Eventually I discovered the driver error while doing uninstalls of OT and things have been fine ever since. I'd check your 002 driver first and run Memtest. Its possible PT11 is accessing previously unused RAM that's flaky.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Shut down as in IM sitting there and all of a sudden you hear a click and the computer is off. It has done it 4 times now since I downloaded PT11. never did it before last Friday when PT11 came out.
probably hardware issues. check Event Viewer to see what kinda errors have been logged. that'll give you an idea and a startin' point...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
HI.
This could be a memory problem. Put an Sandra rapport. |
switched from 001 to 002 and having windows shutting down | sharpd25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-29-2007 08:51 PM |
Windows appears to be shutting me down | nwrstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-27-2007 10:34 PM |
Audio problems when starting Windows & shutting down...help! | jasonguitar | Pro Tools M-Powered (Win) | 0 | 05-01-2007 06:39 PM |
Windows XP Home Shutting down on PTLE Startup! | runner2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-11-2006 11:59 AM |
Windows XP Home Shutting down on PTLE start up | runner2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-11-2006 09:56 AM |
