Cool Sounding Technique
So this is what i want to do:
I have a spoken word track that i am using, but what i want to do is have it start up like an old record player. So that its really slow in the begining and then it speeds up to the correct tempo. how do you do that? |
Re: Cool Sounding Technique
Vari-Fi
Lets say you audio is at 120 bpm and you wanna go from 34bpm and up to 120bpm
Cut you audio at an interval at 10ms (or what ever size you like) Switch you track to ticks Set your tempo change to go from 34 to 120 over 4 bars (or the length you want) Protools will now have change the spaces between you audio Then go in and timestretch each single part And finally select it all and do a batch crossfade on it Select it again and then consolidate it all. My system has a bug (has been reported to digidesign), if i dont consolidate it will crash ... Sometimes the effect above works and sometimes is dosn't ... but its cheaper than buying a product Done by memory so there maybe glitches in it best wishes |
Serato is very good for this type of effect.
Mac Computers/PT12/Lots Of Lacie D2s |
last: PT11.3.1 |
I second the vari-fi vote.
third vote for vari-fi and maybe a light room effect
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
speed by sound toys lets you draw in the speed up. pitch up curve. and its really good
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4 |
Enough replies already,
VARI-FI!!!!! its specifically designed for that exact purpose |
Vari-fi and Izotope vinyl, (its free), plus if you do vinyl to an aud track and record it with no audio, with scratces on, you can get a bump that sounds like the needle landing on the record too...just snap the bump and put it where you want it. i'd do vari-fi before vinyl though... as you want the speed up sound to be affected similaryly to th rest, otherwise you'd here the noise get craz too, and i think that would sound more naturally uniform? right? either way a very nice touch...
Chris Beaver Music www.myspace.com/chrisfrankmusic The Note Music www.myspace.com/thenotemusic Dual 2.0Ghz PPC 3gb Ram, Digi 002R |
Audioslave Technique | ajazzie | Tips & Tricks | 56 | 04-18-2010 04:50 AM |
m/s technique | guitardom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-10-2006 05:35 PM |
Compression Technique | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 12-25-2003 08:21 PM |
Need help with a vocal technique | DDM | Tips & Tricks | 1 | 04-11-2003 02:19 AM |
Cool midi drum technique with Antares mic modeler. | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-04-2002 12:55 AM |
