Old 07-09-2020, 03:24 PM
Wolfgang Eller Wolfgang Eller is offline
Default Re: Output Dither
Dithering just works in the LSB and there is, with 24 fixed / 32 float, always noise.
That's the difference between 24 and 16bit fixed where dithering make sense.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 07-09-2020, 03:45 PM
Anybody who can show me they can hear any difference from any dithering at anything near 24 bits I'll buy them a case of the finest America Budweiser.
Old 07-10-2020, 06:12 AM
NewHere NewHere is offline
Those are all valid points, but I understand this place as the support forum for Pro Tools and didn't came here to get lectured if one should dither or not (there is a discussion over at gearslutz). I simply wanted to know if Pro Tools does this, yes or no. I thought it did, because I misinterpreted the quoted sections of the manual, and came here for clarification. I was wrong and will dither the outputs myself from now on, you don't have to and we can discuss all this over at gearslutz. No disrespect, I was simply seeking for a technical answer from my DAW manufacturer.
Old 07-10-2020, 07:49 AM
I don't know if PT is dithering from 64float to 24fixed but what I know is, that it doesn't make any sense to dither after the physical output.
It needs to be dithered in the 64float to 24fixed conversion process.
If it is already 24bit PCM you're just adding noise without any further advantages.
Old 07-10-2020, 07:51 AM
Ben Jenssen's Avatar
This is NOT a place where you get Avid support. This is a discussion forum for Avid products users.
You do NOT need to have a dither plugin on your output UNLESS you're planning to bounce that output to a smaller than 24bits size file.
PT does NOT "dither the outputs", because it's not necessary. Your interface recieves a stream of 24bit samples and converts them to an analog current, D-A.
...if one should dither or not (there is a discussion over at gearslutz). I simply wanted to know if Pro Tools does this, yes or no.
NO, one should not, unless you're bouncing to a lower bit size, like 16.
NO, PT does not do this.
Old 07-10-2020, 07:52 AM
... which is why it is DAW mixer responsibility. Any dithering plugin has zero effect on or after physical output.
Old 07-12-2020, 07:43 AM
I am sending audio inside of PT to my stem Auxes, which happens in 64 bit. The Auxes are routed to the physical outputs of my DAC which receives 24bit streams. Obviously there is a conversion taking place. Since the DAW mixer doesn't dither, why exactly would dithering plugins on the Aux channels have zero effect? My DAC would now receive dithered 24 bit audio streams. Yes, all that happens way below the noise floor of my desk and yes, since the plugins are pre fader I can't use the Aux faders, but those are not the questions of interest here.
Old 07-12-2020, 07:44 AM
Because the output of dither plugin goes to 64bit mixer that feeds the physical output
Old 07-12-2020, 07:47 AM
Conversion from floating-point to fixed-point is different than fixed to fixed. Which is why you should not worry too much about it. You can think of it (overly simplified) that when you create a fixed-point word from floating-point you get 23 solid bits and the last bit is calculated from the floating point mantissa. So in a sense it is dither in itself. Whatever "errors" there may be are about -140dBFS
Old 07-12-2020, 10:01 AM
ZEUSS ZEUSS is offline
Speaking of Dither, It would be great if we could choose what dither algo to use on "Exporting" files. Goodhrtz,Izotope etc....
As of now if exporting 24 to 16 the stock dither is automatically applied.
In my workflow, I use print tracks and export clips as files. If I want to export say 96K/32 mixes or other clips, and use a better dither, I have to do that out of protools.
A drop down menu "Dither" should be in the export selected box. you would figure that would of been implemented by this point......
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Goodhertz Good Dither — a world-class dither w/ simple controls goodhertz AAX Plug-ins 11 06-01-2015 04:41 PM
Can Dither in Export Prefs be changed to PowR Dither Mr. Anxiety Tips & Tricks 5 10-31-2009 10:28 PM
192 output Dither.. output to Hear System Jeff E Pro Tools TDM Systems (Mac) 10 07-22-2009 10:41 AM
Apply Dither When BTD From 16-Bit Session To 16-Bit Output? Alan Brownstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-25-2008 06:23 PM
PT DITHER x masterist dither x TC masterxdither x l1, q10 dither Alécio Costa Tips & Tricks 9 02-24-2002 01:28 PM
