Old 10-09-2009, 07:20 PM
Dylan360 Dylan360 is offline
Default Microsoft Visual C++ Runtime Library error.
I'm trying to install Pro Tools 8 on a brand new computer (running XP, and no, IE8 is not installed) and when the menu pops up when I put the disc in, and I click "Install Pro Tools LE," I get one of two error messages:
I could not find any information about this error happening with Pro Tools. Is there any way this can be fixed?
Old 10-09-2009, 11:19 PM
x9blade x9blade is offline
Default Re: Microsoft Visual C++ Runtime Library error.
is antiviurus software running??
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 10-09-2009, 11:40 PM
Norton
pardon my computer illiteracy but is that good or bad in this situation?
Old 10-10-2009, 05:35 AM
TCM's Avatar
TCM TCM is offline
Norton is a system hog and I would disable it when you are working in PT.
This error can have several causes:
- incompatible plugins
- Pace driver not up-to-date
- a client has a sloppy programmed rewire connection (Fruity Loops)
But in general it would be good if you posted your system specs:
http://duc.digidesign.com/showthread.php?t=193637
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 10-10-2009, 11:04 AM
temetrepo temetrepo is offline
i'm having a similar problem, but it happens when pro tools starts scanning the plugins. it hangs up on DB-33 :/; i'm going to try removing the digi plugs and see if i can load up the program
brand new pc with a fresh clean install of windows vista ultimate sp1 pt le 8.0.1
no AV running. i only have pt installed no third party plugs or anything else
tried updating the pace drivers and still no luck
gigabyte p55-ud3r
4gb ram ddr3 ocz
geforce 8400gs 256mb
sata 500gb hdd
thanks
Old 10-10-2009, 12:06 PM
http://www.newegg.com/Product/Produc...82E16834114690
This is the computer I bought with what I imagine is everything that would be helpful to know.
Old 10-10-2009, 12:28 PM
TOM@METRO's Avatar
Dylan, just curious, what are you planning to use for an audio drive?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-10-2009, 12:31 PM
TOM@METRO's Avatar
gigabyte p55-ud3r
4gb ram ddr3 ocz
sata 500gb hdd
thanks
temetrepo, you might consider starting you own thread on this, you have a different system and the solution could be very different also.
Be sure you do not have IE8 installed.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 10-10-2009, 02:49 PM
ok. no i do not have IE8 installed. will create a new thread
thx TOM@METRO
Old 10-10-2009, 03:06 PM
I wish I could answer that but again my computer illiteracy prevents me from doing so...
What is an example of an audio drive
Microsoft Visual C++ Runtime Library. Runtime Error!. C:\program files..Pro Tools.exe moonwalker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-05-2012 10:55 PM
MICROSOFT VISUAL C++ RUNTIME LIBRARY ERROR!!!! Keybeeetsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-03-2008 01:17 PM
Microsoft Visual C++ Runtime Library Runtime Error OSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-26-2006 05:40 PM
Microsoft Visual C++ Runtime Library Runtime Error OSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-16-2005 08:28 PM
Microsoft Visual C++ Runtime Library Error Rabidium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-08-2002 10:14 PM
